Here begins the tale of Ambrosio's Unaplex II...
Yes, this is my second theater build. My first build was in a single level ranch with the biggest room becoming my dedicated theater. Unfortunately, when the HT wasn't being used, the house became very small. Also at the time of my build, my budget did not allow for any real sound isolation. At first my wife could tolerate my movie parties but when I added two large 18" DIY subs behind the AT screen, I must admit, it was pretty loud and rattled the entire house. My neighbor said I actually rattled a picture frame off HER wall.
So, we sold the house and now I have a full basement. My wife has given up rights to the right half (and portion of the left) of the basement for my "man cave". The only stipulation was that she had to have unfettered access to the laundry room and storage rooms in the back of the basement. You see, in the last house, I killed the pantry, hall closet and the family room. So her request was not unreasonable to me. The basement was completely finished before I got my grubby paws on it.
**Note**: This basement layout has changed. Look below for the latest layout...or click here
Here is my current vision:
Note that the red walls and hot water heater are to be removed. The blue walls, hot water heater, and separate HVAC are to be added. The yellow circles are my lolicolumns.
If that's too much color, here's the same layout with just the finished "blue" items: Ambrosio's Unaplex 2 layout
I have made initial contact with BPape and he will be on board to hopefully stop me from making any major snafus. I am planning a room within a room with the theater's new ceiling joists nestled in between the current joists. I am going with 3 layers of 5/8" DW with GG. I plan on building an IB chamber ala Cathan and the walls will be finished with fabric frames ala GPowers. I already have my dricore but I cannot put it down until I convert my finished basement into an unfinished basement.
Here's what the room looked like prior to me picking up a hammer and pry bar:
The walls with X's on them is the bedroom wall that will be removed. The IB chamber and AT screen will be back here. The room does look a bit long in the layout and can be adjusted somewhat by making the IB chamber bigger if necessary.
The door by the CO detector is the only entrance to the back rooms and I will be sealing it off as it is on the left wall of the theater not far from where the screen will be.
To make this happen, the water heater in the laundry/sump room was moved near the mechanical room and a new door is to go directly from the lobby/arcade to the laundry room and other back rooms.
To my surprise, here's what I found when I removed the paneling to make way for the new door:
Looks like I'm not the only one who thought a door should go there...
One more before shot:
This is the future lobby/arcade. The back closets will be removed and note the "blue" doorway by the popcorn machine. That is roughly where the new entrance will go. That 200amp electrical panel you see on the closet wall is now gone...thanks Dad! It's not the original panel either. The house was built in '65 and had 100A service. The original box is in the room under the stairs which is just a couple of feet to the left of the panel. It is currently just a junction box and was fed by the new 200A panel. Why they didn't put the new panel in the room under the stairs is beyond me. There was plenty of room to do so. Fortunately, when they removed the old 100A aerial service to the house and installed 200A underground service they spent a few extra bucks and installed a 200A breaker below the power company's meter so we could disconnect the house from the grid and move the 200A panel back under the stairs. This allows me to take the rest of that closet wall out and the driving Xbox 360 cabinet that is mostly finished can be located closer to the wall. The driving cabinet is a blast and will provide stress relief to me when I get burnt out from theater planning/building. If you look close, my previous theater's HTPC is sticking out the front of the cabinet...and do you see the cat6 cable going to it? Yep, that driving cabinet is also a personal hi-def (.mkv files stored on a Unraid server) theater... Yes, I have my own "Drive In Theater" complete with DD/DTS 5.1 surround. A little sub sits behind the 2005 Neon seat.
And here is the room as of now looking toward the IB chamber:
You can see my old sub boxes standing upright behind the 2x4 wall. I killed myself getting these things down the basement (no walkout) and now I am just going to pitch them in favor of an IB chamber...it's Cathan's fault! If anyone near Evansville IN wants them, they're yours...
