Hi all,
I've been reading alot and learning. Trying to plan my home theater build. Want to do my homework before starting.
What I have it a room that is about 18 x 15.
There will be a 20" soffit all the way around at about 7.5 feet high, then the remainder of the ceiling will be 8.5 foot high.
There is currently a wall (load bearing at about 3 feet from front wall. I want to make this the "false wall" and recess the screen in this wall about 18" back, giving me a greater distance from seating to screen. This can be accomplished by building in a header and framing it out to not lose the load bearing traits of the wall. So from the "false wall" to the rear is about 14.5 feet. And from propossed screen location to back wall is about 16 feet.
The "false wall" will be covered with fabric panels made from GOM or the like. This will allow speakers to be hidden behind this wall.
In the diagram, you may be able to get a general idea of what I am thinking.
1. How deep can a shadow box be? How much wider should it be than screen size? I could angle the side walls of the shadow box from front to back instead of square.
2. Can I get a 106" diaganal 16:9 screen in this room with 2 rows of seats? I have shown in the diagram the seating distances from the proposed screen.
I want to put all my front speakers and sub behind the false wall that will be covered in speaker cloth. The surround speakers will be housed in the columns along the side walls. And rear surrounds in columns on back wall.
Seating I hope can be some theater seats in the front and maybe some more simple seating (smaller) in the back row on a raised platform.
I do not have a projector or screen yet. Will most likely build a screen of some sort.
I have not tackled the sound-proofing yet either.
