Carpet Question... - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 6 Old 02-06-09, 11:48 AM Thread Starter
Kirby
Carpet Question...
I am trying to find a black burbur for the stage in my HT. No luck so far, but HD has that really think outdoor carpet my wife says to use due to the price. This is just for the stage, but does anyone know if with this really thin stuff you can use a pad?
And whats the best way to secure it?
I wanted to use regular tack strips, but I dont think I can with this thin stuff.
Thanks
Kirby
kepople is offline
post #2 of 6 Old 02-06-09, 01:42 PM
salvasol's Avatar
David
Re: Carpet Question...
kepople wrote: View Post
That's what I used for my riser (interior/exterior carpet from Lowes) ....you can use flooring glue or there's a tape too
Why do you want to use a pad under the carpet??? ...I think that if you glue it on top of the wood is enough.
salvasol is offline
post #3 of 6 Old 02-06-09, 03:43 PM Thread Starter
Kirby
salvasol wrote: View Post
I wanted to use a pad for comfort but also to make the rolled edge thicker and more gradual.
Applying it direct would be easy but will it look as good?
Kirby
Posted via Mobile Device
kepople is offline
post #4 of 6 Old 02-06-09, 04:37 PM
salvasol's Avatar
David
That will depend on how pick you are
I don't have a good picture of the riser (just the one below), the rolled edge was not a problem to me
Name:  Sub in riser.jpg
salvasol is offline
post #5 of 6 Old 02-06-09, 11:27 PM Thread Starter
Kirby
so what carpet did you use, and did you use a pad?
kirby
kepople is offline
post #6 of 6 Old 02-07-09, 01:02 PM
salvasol's Avatar
David
so what carpet did you use, and did you use a pad? kirby
Interior/exterior carpet from HD/Lowes (less than $3 p/linear foot), no padding ...used tape instead of glue
salvasol is offline
carpet , question...
