| Home Theater Design and Construction Equipment Cabinet DesignDiscuss Equipment Cabinet Design in the Home Theater Installation and Systems forum; Equipment Cabinet Design Sonnie wrote:
I would suspect if I went the cabinet route that I would need to make sure the plane ... |
Views: 1362 - Replies: 34
| | #26 | ||||
| Re: Equipment Cabinet Design If the complete front of the speaker is out from the face of the cabinet, then you should be OK..Still not ideal but the best you can do for that situation.. Prof.. Home Theatre...the never ending story! | ||||
| | #27 | ||||
| Re: Equipment Cabinet Design Gah, I ended up spending the rest of the fun money fund on a new fence. I had almost forgotten about that project. I will post up when I get ready to pursue this again. GL Sonnie. | ||||
| | #28 | ||||
| Re: Equipment Cabinet Design It ain't nothing fancy... but I did finally decide on a final design... ![]() | ||||
| | #29 | ||||
| Re: Equipment Cabinet Design sonnie, check out the equipment cabinet i built for my brother-in-law's theater room. ![]() ![]() ![]() | ||||
| | #30 | ||||
| Re: Equipment Cabinet Design Nice job Matt... ![]() My cabinet guy came by earlier today and stated he would probably make the top and bottom a little larger so it would not be so plain. | ||||
| | #31 | |||||
| Re: Equipment Cabinet Design Quote:
![]() By the way.....I like those Stadiums ![]() P.S.: If he doesn't like the look of the grills, he can use dye to change the color to black (I did it, see my avatar; those are a pair on each side). | |||||
| | #32 | |||||
![]() Prof.. Home Theatre...the never ending story! | |||||
| | #33 | |||||
I tell you what...if you can't have an equipment closet with access to both sides...a cabinet like that is the next best thing. Wiring is SOOO easy. Not like my cabinet where I have to pull equipment out or try to turn it around....what a pain. | |||||
| | #34 | ||||
| Re: Equipment Cabinet Design That is a very clean setup. I like the baseboard type effect around the bottom of the cabinet as well. My cabinet guy is coming by this morning again to do a repair, so I will show him this pic. | ||||
| | #35 | ||||
| Re: Equipment Cabinet Design I ended up telling the cabinet guy somewhat a design like I wanted and he ended up with this... Overall, it works well and is simple enough. I added the velvet type top to eliminate any reflections and it works very well. | ||||
