Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Finally running the speaker wire but....
Discuss Finally running the speaker wire but.... in the Home Theater Installation and Systems forum; Finally running the speaker wire but.... unfortunately I have to cross at a 90 degree several eletrical lines. I hope this does not cause any hum. ...
Views: 489 - Replies: 10
Old 02-23-09, 11:58 AM   #1
Alias: flash
Loc: Lake in the hills illinoi
User: #34210
Since: Feb 2009
  flash is offline
unfortunately I have to cross at a 90 degree several eletrical lines. I hope this does not cause any hum. There is no other way around it. I am running 12 gauge speaker wire cl3 rated. Anyone ever cross several lines of electrical wire and not have any hum. The electrical wire is in metal conduit and my speaker wire is in plastic blue smurf pvc. I guess my best bet is to actually try the equipment and see what happens. Do things like lights, apliances etc. have to be turned on to actually get a hum or is it just in general being in close proximity to those lines.
Old 02-23-09, 12:09 PM   #2
Design and Acoustics Moderator
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
Re: Finally running the speaker wire but....
If you're crossing them at 90 and there is at least a couple of inches between them, it shouldn't be an issue.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 02-23-09, 12:14 PM   #3
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
How close? Shouldn't matter, because at 90 degrees it won't pick up any stray fields. But almost 90 degrees is not 90 degrees, so even a small bit of separation will help.
I even have some runs where the power and signal line up for a couple of inches and there is no hum.
You will probably be fine, but it's good to consider all this beforehand.
Old 02-23-09, 12:19 PM   #4
Alias: brucek
User: #6
  brucek is online now
Do things like lights, appliances etc. have to be turned on to actually get a hum or is it just in general being in close proximity to those lines.
The speaker connections are a high level interface.
You'd have to be arc welding on top of them before you'd ever induce any noise in a speaker connection.
You're confusing them with line level interconnections..
Old 02-23-09, 12:55 PM   #5
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
Doh! You're absolutely correct Bruce. I was thinking low level cabling.
Bryan Pape
GIK Acoustics
Old 02-23-09, 01:09 PM   #6
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
Doh! Too! I got caught up on the same thing.
Glad we cleared that up
Old 02-23-09, 01:14 PM   #7
Alias: flash
User: #34210
Since: Feb 2009
  flash is offline
That brings up another questions. What about HDMI and Sub cable (rca)? Will those be affected by the Electrical lines. I will have one rca and one hdmi for sub and monitor and they will also be running at a 90 degree to the power lines.
Old 02-23-09, 01:30 PM   #8
Alias: brucek
User: #6
Since you've told us that the electrical wire is in metal conduit, then you don't have to worry about any lines near your electrical. It's shielded.
Old 02-23-09, 01:30 PM   #9
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
flash wrote: View Post
What about HDMI and Sub cable (rca)? Will those be affected by the Electrical lines...
I think what Bryan and Anthony wrote in the first post will apply here ...I suggest you to separate the conduits a few inches if you can
Old 02-23-09, 01:39 PM   #10
Alias: flash
User: #34210
Since: Feb 2009
  flash is offline
Great news! Thanks for the info, and back to the construction of my theater.
Old 02-24-09, 10:44 AM   #11
Alias: flash
User: #34210
Since: Feb 2009
  flash is offline
Well, its all good no hum, but..... The speakers hiss a little bit. I think that is normal studio hissing when albums are recorded. Can really only hear it at low volume almost no music. After i turn it up you cant tell its there. If i stop the music there is no hum, so i guess i am good to go.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
but...., finally, running, speaker, wire
