Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
My new Basement HT/Bar area ....
Discuss My new Basement HT/Bar area .... in the Home Theater Installation and Systems forum; My new Basement HT/Bar area .... Hi Shack! I am in the middle of reconstructing my basement to add in a theater "area" and bar. It's ...
Views: 538 - Replies: 6
Old 02-27-09, 08:48 AM   #1
Alias: Matt
Loc: Lansing, MI
User: #19743
Since: Apr 2008
  Spartan is offline
Cool My new Basement HT/Bar area ....
Hi Shack!
I am in the middle of reconstructing my basement to add in a theater "area" and bar. It's not a dedicated, closed area but should be a lot of fun for the family and friends.
-Matt
Old 02-27-09, 08:58 AM   #2
Alias: Matt
Loc: Lansing, MI
User: #19743
Since: Apr 2008
  Spartan is offline
Re: Hi from Mid-Michigan!
Ok -- here's a sketchup that I made. The left side (from the stairs over) is already finished. The right side bottom was a finished room, and the furnace room used to be much larger. I have removed some walls, and am now in the process of painting and putting in a drop ceiling...
Soon I will need to make some decisions about:
- projector
- screen
- automated lighting
- amp?
Hopefully I can find those answers here!
Existing gear includes:
- Pio Elite VSX-01
- JBL 7.1 Studio L (2xL890, 4xL820, L8400P sub)
- Samsung BDP-1500 BluRay
- HTPC running SageTV (with Sage Media Server)
- old VCR & LaserDisc players
Old 02-27-09, 09:10 AM   #3
Alias: Josh
Loc: New Hampshire
User: #31152
Since: Dec 2008
  Quake25 is offline
Welcome aboard!
Looks great so far! What software are you using?
Old 02-27-09, 11:04 AM   #4
Alias: Matt
Loc: Lansing, MI
User: #19743
Since: Apr 2008
  Spartan is offline
Quake25 wrote: View Post
Welcome aboard!
Google Sketchup. It takes a little bit of time to get rolling with it, but once you do, it yields very nice 3D images. If you do want to play with it a bit, I highly recommend checking out the tutorial videos on youtube first.
-Matt
Old 02-28-09, 04:32 PM   #5
Silver Supporter
Alias: Bruce
Loc: Charlotte, NC
User: #13727
Since: Nov 2007
  Bruce Fisher is offline
Re: My new Basement HT/Bar area ....
I think you have too many seats in the bar area... after all you are a Spartan fan - how many people will watch them?? (I'm kidding - wife and I are Purdue alumni )
Looking good!
Have you thought about how you are going to silence the furnace area? I have a similar arrangement with the furnace next to my theater area... and I'm thinking about how to "silence" it as much as possible.
Old 03-01-09, 07:11 PM   #6
Banned!
Alias: Brien Holcombe
Loc: Exit 4, Alabama
User: #10278
Since: Jul 2007
  Space is offline
The only way to stop sound is using mass. It is a misconception that placing huge amounts of sheetrock will stop all sound from entering an area. It will not. When the sound hits a boundary like a wall or a fence it can spread directly around it, if the wave is big enough, go right through it.
Vibration, such as a furnace will produce, and low end rumble, need to be addressed specifically.
Insulation as a sound isolator is a negative effort. It may heat up the highs but over all, it is only part of a good plan.
Depending on what a person has existing as a barrier there may be a requirement to actually tear down some existing work in order to begin towards getting lower levels contained.
That's what I read anyway.
Old 03-03-09, 01:04 PM   #7
Alias: Matt
Loc: Lansing, MI
User: #19743
Since: Apr 2008
  Spartan is offline
I'm not terribly worried about the furnace noise, as it appears to be pretty quiet. Well, quiet enough that we really don't notice it when we are watching things down there already. The only loudness comes from when the humidifier kicks on. You can really hear the water running thru the small copper line. Regardless, i don't anticipate having to do anything about it.
The furnace room will be insulated with R15 & 1/2" sheetrock. Before it only had the sheetrock, so there will be a little improvement.
Overall, I'm not terribly concerned with the noise since we mostly use the basement in the evenings and the furnace doesn't run much then.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
