Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
How to determine optimal room size of basement HT
Discuss How to determine optimal room size of basement HT in the Home Theater Installation and Systems forum; How to determine optimal room size of basement HT Good morning. I have tried out the two posted calculators. I am still not sure how to optimize a room ...
Views: 709 - Replies: 1
Old 03-16-09, 10:48 AM   #1
Alias: Jeff
Loc: Atlanta, GA
User: #31560
Since: Jan 2009
  Bulldawg is offline
Good morning. I have tried out the two posted calculators. I am still not sure how to optimize a room with the following dimensions> Height: 8'-9", Width: 13' - 0", and length 28" - 0". The width and height are fixed, so I can shorten the length. Any ideas on how to optimize for sound and layout of furniture? Thx.
Old 03-16-09, 11:08 AM   #2
Design and Acoustics Moderator
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
Re: How to determine optimal room size of basement HT
Hi Jeff.
One of the things we try to avoid in rooms is to have the length be more than double the width. Depending on your situation and how many seats you want, cutting it back to maybe 24' or so would likely help (and give you a nice space for an IB sub if you want... )
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
basement, determine, optimal, room, size
