| Home Theater Design and Construction Toe's HT setup (work in progress)Discuss Toe's HT setup (work in progress) in the Home Theater Installation and Systems forum; Toe's HT setup (work in progress) http://farzanegan.org/ht
Update- as of last night- I now have the two tempests wired to the EP2500 (not through the 1124).
| | #1 (Link) | |||
| Toe's HT setup (work in progress) http://farzanegan.org/ht Update- as of last night- I now have the two tempests wired to the EP2500 (not through the 1124). Next steps: getting a RS meter and getting this tuned. The bass from my IB is amazingly clear- but not.. loud. I'm going to be really curious how it specs. | |||
| | #2 (Link) | |||
| Re: Toe's HT setup (work in progress) Some specs- the room is over a garage (I have two garages) and I had turned the back 1/3 of the room into a climbing (bouldering) wall. I even make my own holds- ask if you're interested. The size is about 18x23. | |||
| | #3 (Link) | |||
| Re: Toe's HT setup (work in progress) I have a picture of the room I did in Sketchup (free from Google). From the original vaulted ceiling I added a 9' ceiling (much to the dismay of my climbing friends who wanted a taller wall). I also built a wall which is for the screen. What's the consensus on screens- should I buy a screen, build a fabric screen or use the wall with a special paint? | |||
| | #4 (Link) | |||
| | Re: Toe's HT setup (work in progress) That's a good size room toecheese. Looks like you got the whole family involved too... ![]() Screens... I used my wall with 2-3 coats of Kilz 2 and then 2-3 coats of Misty Evening Gray with lots of sanding in between. Looks good to me, but I suspect a nice fabric screen would probably improve my picture some. I'm just happy enough with what I've got. If you are being money conscience then the DIY is much cheaper. Money no object - buy one. | |||
| | #5 (Link) | |||
| Re: Toe's HT setup (work in progress) Oh, saving money is a big motivator. After getting ridiculous quotes on HVAC work, I did it all myself. I also did all the electrical stuff. That paint you mention- is that a special HT paint, or just a Home Depot thing? | |||
| | #6 (Link) | |||
| | Re: Toe's HT setup (work in progress) Glidden Flat Latex Base and I'm pretty sure you can get it at Home Depot. I had mine color matched because there was not Glidden dealer near me at the time. Lowes may have it. I have several screen shots on my site... Z2 and Z4 shots... I think they all look good. | |||
| | #9 (Link) | |||
| Re: Toe's HT setup (work in progress) I got some samples of the screen colors (Misty Evening) and some others and held them up as I watched a movie last night (Dragonfly not too bad, actually) and was... underwhelmed. To be fair, this was a color swatch and not the actual paint, so I might have to paint some actual surfaces to try it. | |||
| | #10 (Link) | ||||
| Re: Toe's HT setup (work in progress) Quote:
I was thinking garage door opener, because they often have remotes and are used to move in two directions with limited motion... dunno. I'm stewing on it. | ||||
