Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
New Construction Planning, Tips, Budgeting help?
Discuss New Construction Planning, Tips, Budgeting help? in the Home Theater Installation and Systems forum; New Construction Planning, Tips, Budgeting help? All, Great forum. I am currently in the beginning stages of planning the finished basement with dedicated theater. As always, ...
Views: 298 - Replies: 4
Old 06-24-09, 12:00 PM   #1
Alias: Spankey
User: #22387
Since: Jun 2008
  Spankey is offline
All,
Great forum. I am currently in the beginning stages of planning the finished basement with dedicated theater. As always, I am finding that compromises and creative thinking will have to be used to get the most out of my budget and space. I am going to say that I have about 10k (maybe 1 or 2 more) to spend on the entire theater. So I am open to all advice and ideas. Here is where I'm at:
Space: The room is about 17x14. The end of the room where the screen will go has one challenge. A sump pump in the corner. I will need to enclose this somehow. I was thinking that I could box the area in instead of a full closet. I could maybe balance this acoustically by placing the sub in the opposite corner.
Gear: This is going to be the biggest cost factor. I will most likely go with a JVC RS-10 and 16:9 screen. Screen size is going to be determined by the amount of space the enclosing of sump will take up. The speakers are B&W Matrix 802's. I am thinking around 6k or so for projector and screen? Sound right?
Audio may also bring a change. Current B&K Ref 31 and Acurus amps may give way to an Arcam AVR600. If I can sell my gear and get a break on the Arcam of any kind, I may be looking at 4k for this upgrade.
That leaves me with about 1 or 2k for cables and other consruction. Will want to build a small riser for two rows of seats. Any suggestions for riser costs or plans welcome, and also pricing of cable.
Rackhis will also be a tough call. Right now I have an alcove under the upstairs fireplace where I was going to build a rack. It is just outside the theater room and will keep the gear out of the theater. The problem is, I can't get behind the wall to connect cables. I saw one pullout option online. I think the cost was about $600. Any other creative ideas on this one?
Paint/Wallcovering: I am most likely going to go with a dark beige, color for the walls. For the screen area, is there a specific black paint I should use or is it better to use fabric? I'd rather user paint if possible.
Thaks for any help. I'm sure I'll have more questions.
Old 06-24-09, 12:30 PM   #2
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
Re: New Construction Planning, Tips, Budgeting help?
As for rack placement, if you are enclosing a closet around the sump pump, you may be able to build in a rack unit on one of the walls. Then you can step in to wire it from behind.
I wouldn't worry too much about wiring access as long as the alcove is ventilated enough for your big offenders (preamp, power amp, sub amp, etc). Just oversize your cables and have enough room to push the slack back when you slide the unit in. An adjustable sawhorse or table is good to support the equipment while you wire it up. Also zip ties are your friend, even when the gear is hidden. You can creatively place them to force the wires to "S" collapse as you push the gear back.
I think it was mid atlantic or atlantic racks (forget the brand name) that has slides and a spin platform, but it's $500 for the small one. For that kind of money, you can look at other options altogether. You can get a fake closet built, drywalled, and painted for that.
Good luck and keep us posted!
Old 06-24-09, 12:38 PM   #3
Alias: Spankey
User: #22387
Since: Jun 2008
  Spankey is offline
Thanks for the tip, I was thinking of the Accuride pull out system, but would prefer a solution other than buying something for $500 plus.
Old 06-24-09, 12:48 PM   #4
Design and Acoustics Moderator
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is online now
Don't go overboard on cable. Just get quality construction and you'll be fine.
I don't see any money budgeted to treat the room. That will bring you as much or more improvement in sound quality than a new processor/receiver considering what you already have - and do so for a lot less money.
I'm also assuming that the budget doesn't include the cost of seating.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 06-24-09, 01:42 PM   #5
Alias: Spankey
User: #22387
Since: Jun 2008
  Spankey is offline
I didn't include seating and room treatment because I may be able to save some money here and there on construction. I will be working with a contractor, so I don't want to plan ahead, but really want to focus on the bones of construction.
Seating is definitely in the equation. May come out of pocket though.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
budgeting, construction, help?, planning, tips
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
