| Home Theater Design and Construction Solid Core Door for HTDiscuss Solid Core Door for HT in the Home Theater Installation and Systems forum; Solid Core Door for HT I want to install a solid core door with weatherstripping at the entrance of my HT. The opening is about ... |
| | #1 (Link) | |||
| Solid Core Door for HT I want to install a solid core door with weatherstripping at the entrance of my HT. The opening is about 3' x 7.5', so it shouldn't be too difficult. I went by HD but didn't see much to my liking? Do you guys know of a good solid core door supplier (with the frame attached)? Any recommendations on what to get or how to install it? | |||
| | #3 (Link) | ||||
| Quote:
www.zerointernational.com --Ethan RealTraps | ||||
| | #4 (Link) | |||
| Re: Solid Core Door for HT Hi! I once visited a studio that had an nonstandard sized door. When I asked why, I was told that they couldn't easily find a ready made one, so they decided to make to size to fit the hole in the wall. They made it out of wood mainly, filled with sand. It worked great. If your a DIY kind of person you could have a go. Sorry if I haven't helped. | |||
| | #5 (Link) | |||
| Re: Solid Core Door for HT Eddie... thanks for the suggestion! I ended up custom ordering one from HD. I wanted it to match the rest of the internal doors in the house, but be solid core. I ended up getting one for $100+tax (pre-hung, 3 hing, single bore, etc). I'm not too worried about complete isolation so it's designated for indoor use. I'll have some sort of skirt hanging below to block all light, and may ultimately put a threshhold in. We'll see what happens after it arrives. | |||
| | #6 (Link) | |||
| Re: Solid Core Door for HT Jagman, I would contact HD and have them custom order the door. I have a set of solid core double doors that took a while to get...but well worth it for the sound isolation. Later RayJr Welcome to The Coronado Home Theater Home Theater Junky...on a budget My 15 Minutes of Fame My "OTHER" 15 Minutes of Fame | |||
| | #7 (Link) | |||
| Re: Solid Core Door for HT Funny you mention that. I ordered it a couple weeks ago and picked it up last Friday. Looks very similar to the doors in the house... even the most anal retentive person would have a hard time noticing the difference. I haven't installed it yet, but it'll be pretty easy. I'll post pics of my HT when it's done. I posted pics of my room treatments a few months back but have made some changes. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| The Upgraded Monarchy Audio SE-250 Hybrid (Tube/Solid State) Monoblock Power Amplifi | Sonnie | Home Theater, Audio and Video News | 0 | 06-25-06 01:59 AM |
