theatre design - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
theatre design
Discuss theatre design in the Home Theater Installation and Systems forum; theatre design i have a large space in my basement that im finishing as what i thought would be a dedicated room ...
Old 01-09-07, 03:08 PM   #1 (Link)
Alias: rod
Loc: missouri
User: #5486
Since: Jan 2007
tlcmetrokc is offline
theatre design
i have a large space in my basement that im finishing as what i thought would be a dedicated room for the theatre. im rethinking this to still be dedicated but with a pool table and gaming area inside also. what do you guys think its about 50' long x 24'wide x 8' finished ceiling??? concerns with speaker placement
Old 01-09-07, 03:25 PM   #2 (Link)
Loc: Lower Alabama
Re: theatre design
If it were mine, I divide it up into two rooms. For the home theater 14' x 24' or 16' x 24' and use the rest for the game room. This way if someone wants to watch the cinema, they can do so without listening to pool balls crack each other. You have a lot of space and have a lot of options.... and if you have the option of making the HT dedicated, take advantage of it being truly dedicated.
Welcome to the Shack!
Sonnie
Old 01-09-07, 04:43 PM   #3 (Link)
Alias: Alan
Loc: Denver, CO
User: #975
Since: Jun 2006
Alan Brown is offline
Lightbulb Re: theatre design
You have to decide what your usage priorities really are. Do you want optimum sound isolation, acoustics for the best audio reproduction, absolute light control for the best picture on the screen, correct speaker placement, etc., for enjoying movies? Will you spend more time on playing pool or throwing parties, rather than critical movie viewing sessions? A theater with a pool table in it is no longer a dedicated theater. You will then have a multi-purpose room. Were you planning a front projection system?
Just remember, the room is as important a component in the system as any other piece of equipment. You can literally compromise the performance and value of your electronics dollar, and every program you watch or listen to, with the wrong room design. It's your lifestyle and your money. You have to think through what's important to you and how you want to use the space.
Remember to avoid room dimensions that are multiples of one another. That will help prevent grossly uneven bass energy distribution around the room. Bad bass distribution results in one seat with very little bass energy while at another seat you'll want to turn the bass down. A very bad idea would be 16 x 24 x 8.
Best regards and beautiful pictures,
Alan Brown, President
CinemaQuest, Inc.
ISF, THX, SMPTE, CEDIA
"Advancing the art and science of electronic imaging"
Old 01-09-07, 07:36 PM   #4 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is online now
Re: theatre design
If you will use it more and enjoy it more as a combo room - do it that way. Just understand that there are compromises with this solution. Not that they can't be overcome because they can. You just need to plan accordingly. 8x24 is a multiple. 24x50 is close to a multiple. We can deal with them but it's harder to start with.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 01-10-07, 07:32 AM   #5 (Link)
Alias: rod
Loc: missouri
User: #5486
Since: Jan 2007
Re: theatre design
i appreciate the feedback. i am a pro audio engineer in the auditorium and arena area. when doing home audio it seems theres a seperate set of rules. i have mostly denon hardware and paradign speakers. i plan on using the same in the new room. i want a good hd projector that wont break the bank. i have a local company coming out to give me some ideas. i am a local contractor by trade and am finishing my basement finally. before i commit to the framing design i would like several ideas on design. thanks for any input you can and have given.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
Similar Threads
The New Theatre Prof. Home Theater Gallery 24 07-09-08 07:20 PM
Steve's New Theatre Steve Williamson Home Theater Design and Construction 75 04-16-07 03:53 PM
Brads Home Theatre zetabass Home Theater Equipment 3 12-31-06 09:50 AM
Home Theatre system help dvdsung Home Audio Speakers 4 10-16-06 06:53 PM
home theatre alan monro Welcome | Member Introduction 5 05-16-06 03:06 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
