| Home Theater Design and Construction New Equipement rack...Discuss New Equipement rack... in the Home Theater Installation and Systems forum; New Equipement rack... Hi Everyone.
I thought I'd share a new equipment rack I built for my HT:
Construction was simple: 3/4 oak ... |
Views: 1172 - Replies: 14
| Hi Everyone. I thought I'd share a new equipment rack I built for my HT: ![]() Construction was simple: 3/4 oak veneered plywood for the top, bottom, shelves and sides. The front of the shelves have a bit of bull nose trim to cover the plywood. The top, bottom and sides are trimmed with 1x2 solid oak - this covers the exposed edge of the plywood, and also allows a 3/4 inch overhang so you don't see the cut drywall. To support the shelving, I went with some tracks on the sides - I used a router to groove out the wood so that the tracks would be flush. (I had used pegs in holes before, but thought I would try this approach this time) - Jack - Jack | ||||
| | #3 | ||||
| Re: New Equipement rack... Thanks Wayne, the cabinet took some time, mainly because we have 2 young kids and time is pretty hard to come by. What helped alot, was that we have a specialty wood supplier in the area- They'll cut plywood to any dimension - I don't own a tablesaw so I had them cut all the plywood. Once that was done, I just had to router the slots for the supports, and stain and finish the oak. Of course it helps living in an area with Basements - Do they have basements in Texas? - Jack | ||||
| | #4 | |||||
| Re: New Equipement rack... Quote:
Regards, Wayne | |||||
| | #5 | ||||
| Re: New Equipement rack... Thats a drag, but on the other hand, basements are expensive to dig, and all that concrete is expensive too - so for what it cost for our basement, you could probably add a nice 15x18 addition in Texas. (hopefully) - Jack | ||||
| | #6 | ||||
| Re: New Equipement rack... Very nice looking rack basementjack...Just a couple of questions..Do you have access to the rear of the cabinet? and do you have any type of cooling? it looks like it could get quite hot in there.. | ||||
| | #7 | ||||
| Re: New Equipement rack... Yeah the back is open to the rear of the basement. For that shot, I covered it wth black fabric. I still need to build a door and do something for ventilation. I was originally going to install a small 120v computer fan on the top, but I've since decided to use the top of it for a monster power center so top venting is out. my next plan was to install the fan on the door, right behind the reciever/amp. I need to evaluate if this will work though - I put a temporary 120v box fan back there, and the motor was inducing hum into the signal path - likely thorugh the wiring between the preamp/amp. so I may need to either add distance between the fan and the wireing, or it may be worth trying a 12v fan to see if less magnetic interference is generated. For now, I am short a projector, so all I've done is short periods of 2 ch music, or test tones. - Jack - Jack | ||||
| | #8 | ||||
| Re: New Equipement rack... Jack ,that rack and oak trim look great.I also looked at your pics of the whole room it looks great and big.But I think you need to get busy building some acoustic treatments so that those Paradigms can sound their best. Fred Last edited by F1 fan; 01-21-07 at 08:42 PM.. | ||||
| | #9 | ||||
| Re: New Equipement rack... If you could see the room as it is now... The pictures on my site are old. I've got a 5'x8' acoustic panel on the right wall, I love that thing. It's a fabric track thing - put the 1" 6# insulation on the wall, staple a PVC track on 4 sides, pull the fabric over the track edge and snap shut - easy and cheap, then the company that made the track went away... I had always intended to add more... Then I got the idea to build some tube traps, so I did 4 small and 2 large. That was just last fall, then I got the idea to make the cabinet. So now I've got more room for the traps, but I need to spend about 6 hours with some software and take measurements before and after to see what works and what does not. The room sounds pretty good, but there's a definate null at 50 hz, so once I confirm that the tubes actually do what they are supposed to, I'll probably write them off as a learning experience and do something different (I get too many 'what are those' questions, usually accompanied by rolling eyes ) I think some diagonal panels in the corners may just be the way to go - I just have to decide how to trim them out.- Jack | ||||
| | #11 | ||||
| Re: New Equipement rack... lol... Very nice work Jack... Very nice! | ||||
| | #13 | ||||
| Re: New Equipement rack... Jack is on leave for a while, so he may not respond so soon. Don't want you to think he is intentionally ignoring you, but it may be a while before we hear from him again. Did you use 3/4" birch or oak plywood or just plain ole plywood? Generally the good stuff will not warp unless it gets wet before it's finished. That other stuff I wouldn't trust at all. | ||||
| | #14 | ||||
| Re: New Equipement rack... Thanks for the heads up. I used 3/4" birch, seemed like good stuff. I was thinking of putting 2" trim on the front of each shelf ,maybe it would not warp? (the shelf may have a bow but trim would not?) | ||||
