Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Calculating Room Modes - Odd Shaped Room
Discuss Calculating Room Modes - Odd Shaped Room in the Home Theater Installation and Systems forum; Calculating Room Modes - Odd Shaped Room Bob in St. Louis wrote: What am I missing Ethan? Bob What you're missing is that whatever adjustment you apply ...
Views: 2495 - Replies: 25
Old 02-20-07, 01:15 PM   #26
Alias: Ethan Winer
Ethan Winer's Avatar
Loc: New Milford, CT, USA
User: #1679
  Ethan Winer is offline
Lightbulb Re: Calculating Room Modes - Odd Shaped Room
Bob in St. Louis wrote: View Post
What you're missing is that whatever adjustment you apply with EQ will be valid for only that one cubic inch location in the room. You can't even make the response the same for both ears at the same time. Having a lot of bass traps and other absorbers reduces the variation at different locations, but it's still there.
--Ethan
RealTraps
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
