Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Glass window for projector?
Discuss Glass window for projector? in the Home Theater Installation and Systems forum; Glass window for projector? I have my projector behind a window. I noticed when installing the glass, that the picture dimmed noticably. I'll say ...
Views: 2334 - Replies: 9
Old 02-18-07, 11:29 AM   #1
Bronze Supporter
Alias: jack
basementjack's Avatar
Loc: Chicago Suburbs, IL USA
User: #2649
Since: Sep 2006
  basementjack is offline
Question Glass window for projector?
I'll say 10-15%
Has anyone else put their PJ behind glass? Any info on what kind of glass (or plexi) would minimize image loss?
the glass I'm using is 1/8 inch thick - appears clear to the naked eye (I'm no glass expert),
- Jack
Old 02-18-07, 12:15 PM   #2
Design and Acoustics Moderator
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
Re: Glass window for projector?
If you're going to do that, you need to use optical quality glass for just the reasons you noted.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 02-18-07, 12:40 PM   #3
Bronze Supporter
Alias: jack
User: #2649
Since: Sep 2006
when you say 'optical quality glass' - is this something an average glass place would know about/stock? Are windows made with optical quality glass? maybe I bought 'shelf' glass instead?
- Jack
Old 02-19-07, 05:42 PM   #4
Shack Moderator
Alias: Prof.
Prof.'s Avatar
Loc: South of Adelaide
User: #3204
Since: Oct 2006
  Prof. is offline
Jack...I'm no expert in this area but it sounds like you could be getting some light "bounce back"..
Normal window glass has a reflective surface...If you look at a framed picture with a glass covering, you can see light reflections on the glass face..This is why they use non-reflective glass on paintings, so it doesn't detract from the image..
This may be the type of glass you need for the projector..
Old 02-19-07, 07:25 PM   #5
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
A normal glass place won't know. Google is your friend. Look on AVS too.
Bryan
Bryan Pape
GIK Acoustics
Old 02-20-07, 05:37 AM   #6
Alias: Steve
Steve Williamson's Avatar
Loc: Gold Coast Australia
User: #496
  Steve Williamson is offline
I am after the same glass as you, I saw this article a while ago, but have not chased anything up yet about it: http://www1.electronichouse.com/article/6682.html
A small hole was cut into the wall, and theater glass, like that found in commercial movie theaters, was installed in front of the lens to allow the light to pass through while blocking heat and noise generated by the projector
If you find anything, let me know the product details.
Old 02-20-07, 06:42 AM   #7
Alias: Bryan Pape
User: #2579
Since: Sep 2006
  bpape is offline
http://www.avsforum.com/avs-vb/showt...ss#post9642814
Bryan Pape
GIK Acoustics
Old 02-20-07, 08:09 AM   #8
Alias: Steve
User: #496
OK, I found that Pilkington's have the Optiview range in Australia, I will try to talk to their rep about the product including pricing:
Pilkington OptiView™ reduces glass reflection to less than 2% compared with 7% for standard float glass when viewed from both the inside and outside
Hopefully that will enable me to soundproof the pj completely.
Old 03-27-07, 05:18 AM   #9
whiteknightoz
Inactive
Alias:
User: #
Posts: n/a
Steve,
Let me know what size you are after and they price they give you. Might be able to save you a few bucks.
Old 03-27-07, 06:27 PM   #10
Alias: Steve
User: #496
Managed to get a sample - 100mm by 100mm for free, problem is, the AE1000E arrived and the front is like a hairdryer, I have to cut the bulkhead to allow the whole of the front to breath through.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
