| Home Theater Design and Construction Which RoomDiscuss Which Room in the Home Theater Installation and Systems forum; Which Room Hello, Great forum and i love looking at all the HT room pictures.
I have a 52in tv with Polk ... |
| | #1 (Link) | |||
| Which Room Hello, Great forum and i love looking at all the HT room pictures. I have a 52in tv with Polk speakers and sub and a Yamaha tuner. I have this setup in a small empty bedroom. I was thinking of moving all my gear in small living room. Do most of you prefer your stuff in living room or a dedicated room? Any suggestions welcomed.. Thanks. Mark | |||
| | #2 (Link) | |||
| | Re: Which Room Great to have you join! As to your question, I'd much rather have a dedicated room -- the main reason being that you can usually set up the equipment to maximize the best sound of your system. A living room setup usually involves a lot of compromises. And forget about adding any kind of acoustical treatments in a living room -- at least if you're married. ![]() JCD | |||
| | #3 (Link) | ||||
| Re: Which Room Quote:
I second JCD's opinion ... ![]() ![]() ![]() I used to have my TV and surrounds in my family room; sound was okay .. ![]() ![]() I found some theater chairs at a good price ... I bought them, and after that I started changing everything and decided to convert a room into a dedicated HT .... I'm very ![]() ![]() ... I wouldn't go back to having my HT in a Living/Family room .... if possible, "DEDICATED IS THE WAY TO GO" ... ![]() ![]() ![]() | ||||
| | #6 (Link) | |||
| Re: Which Room You just need to make them look good, and then find a woman who appreciates "modern art". (or home theater, I guess) Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Calculating Room Modes - Odd Shaped Room | Bob in St. Louis | Home Theater Design and Construction | 25 | 02-20-07 12:15 PM |
