| Home Theater Design and Construction Looking for 12v-triggered switchDiscuss Looking for 12v-triggered switch in the Home Theater Installation and Systems forum; Looking for 12v-triggered switch New to the forum, so hello everyone. I will keep my first post brief.
I am looking for a switch ... |
| | #1 (Link) | |||
| Looking for 12v-triggered switch New to the forum, so hello everyone. I will keep my first post brief. I am looking for a switch that can be triggered by a 12v on signal (not pulse, but on or off), that would switch a 5v signal from Normally open (NO) to Normally closed (NO). This is for my projector lift. I would then use the 12v signal from my projector to trigger the lift. Basically it would be two input wires for the 12v signal, plus a 3-wire switch: 5v signal, NO, NC. I have tried to Google to find it, but can't find what I am looking for. Any suggestions? Thanks, Mike | |||
| | #2 (Link) | |||
| Re: Looking for 12v-triggered switch Simple SPDT relay will do the job. Find one with a coil voltage requirement of 12volts with a current that is lower than your projector can source. For example 12v@50ma coil where the projector spec might be 12v@100ma. Then ensure the contacts of the relay can handle the current rating of the lift... brucek | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Adapter to convert 120v to 12v | Methodical | Remotes | Cables | Accessories | 7 | 02-05-07 09:12 AM |
| 12V Trigger AC Outlet | Josuah | Home Theater Components | 2 | 01-30-07 04:39 PM |
| 12V Trigger specifications/standards | TedT | Home Theater Components | 14 | 11-04-06 07:03 PM |
| Stupid question(s) regarding 12V Trigger | Fincave | System Setup and Connection | 8 | 11-03-06 07:59 PM |
| Music/Movie Switch = Slam/Depth Switch??? | Daddy Cool | Home Audio Subwoofers | 9 | 09-14-06 03:10 PM |
