Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater Installation | Systems > Home Theater Design and Construction
  Discuss Help with riser construction. in the Home Theater Installation | Systems forum; Help with riser construction. Hey guys, I was wondering if someone could give me some help with building a sturdy riser. I have a ...
Views: 2102 - Replies: 13
Old 03-27-07, 09:08 PM   #1
Alias: rob
robk_11's Avatar
Loc: palmyra, pa
User: #6308
  robk_11 is offline
Hey guys, I was wondering if someone could give me some help with building a sturdy riser. I have a sofa and love seat that I moved down to my under construction basement HT. The wife argues against it (of course), but I would like to put the loveseat on a riser behind the sofa. She would rather have the loveseat Blocking the front right speaker :raped: . It is a never ending struggle... I know it is just building a box, but can anyone give me some material recommendations to make the thing sturdy enough to hold some poundage!
thanks as always,
Rob
Old 03-27-07, 10:47 PM   #2
Alias: Chuck
Loc: Colleyville, Texas
User: #5134
Since: Dec 2006
  chhelo is offline
Re: Help with riser construction.
Rob,
I built my riser using the concept by Auralex for a tactile riser. I basically used 2x10's on edge and used manufactured decking material from Lowes for the front and back of the riser. Decked it in 3/4 inch OSB. Since my theater seats are curved I built the riser with a curve to match. Only change I might have made is 2x12's instead of 2x10's. I also added side access steps at about 6 inches for the step up.
Per the info on the riser I used insulation bats to fill in between the 2/10's to about 1/2 the height. Also calls for 4" holes cut into the front face of the riser for bass response.
Decoupled from floor with 5/8" radiator hose (4 2" pices under each 2x10).
You can see basic layout under Chuck's Home Theater post.
I do not have my equipment up and running so I am unable to confirm if it will have a tactile response. If it need more motion I will add buttkikers to my theater seating.
It is about 7 feet deep to allow for the chairs to recline. If you are not using reliners the riser can be smaller.
Tell the wife the riser is for the premium seating and since its the love seat position its just for you and her. She will buy that hook, line and sinker.
Chuck
Old 03-28-07, 06:14 AM   #3
Shack Moderator
Alias: Bryan Pape
bpape's Avatar
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
I would agree with the construction above except for the radiator hose. Over time, it will crush and get hard. Use something like a stud isolator that is specifically designed for that kind of weight load, constant pressure, etc.
Good luck with the battle
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 03-28-07, 12:53 PM   #4
Alias: chad
User: #7756
Since: Mar 2007
  cburbs is offline
Here is an example of a riser.....
http://www.ronniejackson.com/theater/seating.html
Old 03-28-07, 12:57 PM   #5
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
bpape wrote: View Post
I would agree with the construction above except for the radiator hose. Over time, it will crush and get hard. Use something like a stud isolator that is specifically designed for that kind of weight load, constant pressure, etc. Good luck with the battle Bryan
I also agree with not using the radiator hose ....I'm in the process of adding a buttkicker and been looking for something to isolate my seats; I have decided to get the isolators recommended by the company.
I saw them on www.av-outlet.com set of 4 for a chair/sofa is $9.99 and for a platform is $15.00 a piece, you need at least one for each corner.
Good thinking about adding this isolators now ... not like me, that I didn't plan ahead
Good luck with your wife, I'm sure she will be Happy after you build the riser
Old 03-28-07, 01:12 PM   #6
Alias: rob
robk_11's Avatar
Loc: palmyra, pa
User: #6308
  robk_11 is offline
thanks for the recommendations. i will take them into account. the wife will have to like it b/c it is going to happen ! at least i hope... i like the buttkicker idea too. i'm going to have to do further research into those.
Old 03-28-07, 01:26 PM   #7
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
robk_11 wrote: View Post
I will save you some time reserching prices (I can't say anything about them because I have not installed it, hopefully I will get mine this weekend, but I read good things about it )
Best price is from one of the sponsor here Ultimate Home Entertainment (www.rtheaters.com), there is a lot of companies selling them and the price starts from $389.99 and up, but I can tell you that if you get it from Ultimate it will less than that.
Old 03-28-07, 10:33 PM   #8
Alias: rob
robk_11's Avatar
Loc: palmyra, pa
User: #6308
  robk_11 is offline
thanks for doing the leg work for me David!
Old 04-07-07, 09:38 PM   #9
Alias: Shane
Loc: Holden Beach, NC
User: #7064
  SurfHB is offline
Here is my riser construction with 4 Buttkickers built in. I love the way it turned out.
http://good-times.webshots.com/album/556829749cekeBe
InFocus 5700 Projector
Marantz SR7002 Stereo Receiver
5.1 Infinity Surround Sound speakers with a Powered 10 inch Subwoofer
Buttkicker Amplifier BKA1000-4A
4 LFE Buttkicker's
DIY 110-inch Movie Screen
Magnavox MDV456 DVD/CD Progressive Scan Player
DirecTV HD Satellitte Receiver
Modified X-Box with 4 wireless controller's
XBox 360 with 4 wireless controller's
Old 04-09-07, 02:34 PM   #10
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
SurfHB wrote: View Post
Nice work !!!! ..... Did you use any rubber isolator to separate the riser from the floor??? ...I was looking at the photos but couldn't find them.
Did you had a hard time calibrating them??? ... What settings are you using (high crossover on or off, What is the cut off limit you're using??, volume )???? ... I want to experiment with mine .... Right now I have the low filter off, high filter on and crossover at 80Mhz ... volume is only one third and shakes all the room ......
« Home Theater Shack > Home Theater Installation | Systems > Home Theater Design and Construction »
Bookmark and Share
Dish Network
