I'm planning a small home theater in my basement but I'm limited on room size specifically
7.5 ft h x 9.5ft w x 13ft d. I was planning to put the screen on the 9.5 ft wall and hopefully have two rows of seating my first question is are the dimensions ok to work with. I'm in the planning stage for the room so the equipment & screen size is flexible also the only flexible room dimension is the 9.5ft wall which could be made wider. thanks
