Hello All,
I'm looking for input on whether my space available will fulfill my needs. I want to go with a projector and was thinking of possibly a Plasma or Led as an addition. Also I'm a strong believer that the audio should at the minimum be on par with the visual if not exceed it. I also feel that when it comes to technology your better looking at the future rather than buying for the present. So...I'm thinking 7.1 or even 7.2
The size of the screen is up in the air and would depend on the location. My original idea was to use a 11x14 space but someone mentioned to me that I probably wouldn't achieve the results I wanted.
1 the screen even if I went with something like a 90" or 80" for that matter would be too close for viewing and wind up giving me a headache.
2 The audio wouldn't be able to achieve its full potential in this area.
So which way would everyone tend to lean. I have some support columns in the basement and was going to use them to guide me in my layout. Also the reason that wall is on a 45 was because I was putting a Saltwater tank in the wall.
Thanks for your time!
http://www.hometheatershack.com/forums/attachment.php?attachmentid=30456&stc=1&d=1300850328
