Handy placement guide - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Discuss Handy placement guide in the Home Theater Installation and Systems forum; Handy placement guide In the spirit of giving something back , ( in acknowledgement of your generosity in making REW available ) I'd ...
Old 06-10-07, 12:57 AM   #1 (Link)
New Member
Alias: Evan
Loc: New Zealand
User: #9403
Since: Jun 2007
Hitmaker is offline
Wink Handy placement guide
In the spirit of giving something back , ( in acknowledgement of your generosity in making REW available ) I'd like to share something I found in my travels ... which I think would be a great boom for those looking into sub placement .
If you go here .....
http://www.hunecke.de/english/calcul...igenmodes.html
you will find a JAVA tool that , having used the room data you feed it , will reveal some readings on your room .... also ... down the page ... will display visually where your pressure buildups ( standing waves ) are .... at a number of useful frequencies ...
In the context of say knowing you had a hump in your low-mid spectrum , if you wanted to find a spot in the room least affected , at which to place your sub ... then select the frequency of your 'hump' .. and see them ... for yourself ....
Cheers ...
Old 06-10-07, 06:16 AM   #2 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
Re: Handy placement guide
That looks like a very handy tool.
Thanks mate.
Hakka.
Old 06-10-07, 06:24 AM   #3 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
The room acoustics and loudspeaker calculators on that site are worth a look too.
Hakka.
Old 06-11-07, 01:04 AM   #4 (Link)
New Member
Alias: Evan
Loc: New Zealand
User: #9403
Since: Jun 2007
Hitmaker is offline
Hi Haaka ,
The handiest thing I find with the acoustic analysis , is , if under your choices of absorber system you go 'Wall and Ceiling systems' , and then select one of the OWA products that is close in performance to the treatment design you've chosen , it will reveal what area of treatment you will need , dependent on what acoustic environment you're working toward. Not having to guess as to how many traps/absorbers you will need , takes some of the black out of the Art .....
Cheers ,
Evan .
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
Similar Threads
Anyone use 'The AVIA Guide to Home Theater'? SteveB Video Displays and Processors 10 01-20-07 12:15 AM
An unbiased guide to buying a plasma HDBeat Home Theater, Audio and Video News 0 08-22-06 11:43 PM
An unbias guide to buying a plasma Wayde Home Theater, Audio and Video News 0 08-18-06 01:40 PM
thanks for the guide! cyberbri BFD Forum 2 08-08-06 03:58 PM
Guide to Sub box Design Danny DIY Subwoofers 12 05-13-06 10:48 AM
Mach 5 Audio
