Cable terminators: what's best? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Discuss Cable terminators: what's best? in the Home Theater Installation and Systems forum; Cable terminators: what's best? (Couldn't find a thread specifically for this -- just point if I missed it.) In a dedicated HT room, what's ...
Old 06-18-07, 01:19 AM   #1 (Link)
Australian Contingent
Alias: John Simpson
Loc: Hobart, Tasmania
John Simpson's Avatar
User: #8852
Since: May 2007
John Simpson is offline
In a dedicated HT room, what's the preferred (ie: best sonically) method of terminating speaker cables? Someone once told me wall plugs are bad because they add a weakness to the run -- even the high-end plugs. They look so neat though...
Similarly, when you attach cables to drivers for an IB system, should they always be soldered in place? If so, with what type of solder?
Finally, when plugging in cables, banana plugs etc, should you coat them with any sort of conductive grease? I'm thinking something along the line of thermal paste on a CPU, but rather than heat it conducts electricity, thus improving the connection...
Old 06-18-07, 04:32 AM   #2 (Link)
Alias: alan monro
Loc: Melbourne Australia
alan monro's Avatar
User: #465
alan monro is offline
Re: Cable terminators: what's best?
John . Use any termination you like makes no difference . also if you have screw terminals on your speakers use them also makes no difference . Who said one has to use a conductive grease again makes no difference If one has to solder use normal solder . Kind regards ,Alan
Old 06-18-07, 05:59 AM   #3 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
If you solder, just make sure you use resin core and not acid core solder. Also, since I don't know how much you solder, I'll just remind that when you solder, you must make a good soild mechanical connection before soldering.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 06-18-07, 09:18 AM   #4 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is offline
Hi John,
I'd agree that most of it won't make that much difference as long as you have a good physical connection. I use solid banana plugs at both amplifier and speaker ends (well, my mains and center actually force me to use spades, but I used bananas on my previous speakers, which would accommodate them).
If you want to use wall plates, I think you should be fine as long as you get some of decent quality. Personally, I would probably not use them for the mains, as I like to do a lot of two-channel listening, and I like to keep that path as clean as possible. I don't think that a pair of wall plates will make that much difference, but I have a clean run from amp to speaker, so I just go direct. For center/surround, I'd be fine with wall plates, but those also just happen to be run directly as well.
I've never heard of anyone using a conducting paste of any type, but if you get the right color and market it correctly, you could probably sell it for megabucks to the right guys (I'm thinking $499 for a toothpaste-sized tube) . I don't think it will make any difference if it's already out there.
The important thing is to use an appropriate-sized cable for the length of your run, and to keep a solid mechanical connection at the terminals.
-- Otto
Old 07-07-07, 08:54 AM   #5 (Link)
Alias: John Simpson
User: #8852
Since: May 2007
Bumping this again, does anyone know of a manufacturer that sells *nice looking* wallplates for speaker terminations, HDMI, component, etc? I've seen a few different types around, but they all look very 80s. Something with a brushed metal finish would be nice...
View our home theatre project at the Wychwood website. Comments welcome!
Old 07-07-07, 09:09 AM   #6 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
www.markertek.com
If they don't have it, they'll make it.
Bryan
Bryan Pape
GIK Acoustics
Old 07-08-07, 08:46 PM   #7 (Link)
Alias: Dan
Loc: Australia
User: #359
Danny is offline
I also like the speakon connectors. Handle i think 3000Watts from memory per conductor. You can also get nice wallplates for them. Try Jaycar for the plates or Entertainment services one of them sells wallplates.
Old 07-09-07, 01:19 AM   #8 (Link)
Alias: John Simpson
User: #8852
Since: May 2007
I just found an Australian site by accident that has some very nice looking wallplates... made using Clipsal plates as the base, so they're certainly well constructed.
View the site here
Here's a question: are all HDMI plugs the same, if they're 1.1 or 1.3? I thought about buying this wallplate, but wondered if the PS3's HDMI 1.3 would work through it... any ideas?
Old 07-09-07, 05:00 AM   #9 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Those should work just fine.
Bryan
Bryan Pape
GIK Acoustics
Old 07-09-07, 08:00 AM   #10 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
As for wall plates for HDMI, Parts Express sells the Impact Acoustics RapidRun, which is the only custom wall plate for HDMI on the market (now).
It's nice because it allows varying lengths and the cable is rated for in-wall use.
There are others that make wall plates to use existing cable on, but the runs are limited to around 25' (not active) and the cable is not in-wall rated.
As for speakers connections, I like locking banana plugs or spades whenever possible.
Old 10-19-07, 09:47 AM   #11 (Link)
Alias: Zip
Loc: Canada
MatrixDweller's Avatar
User: #10408
Since: Jul 2007
MatrixDweller is offline
I bought my wallplates from www.monoprice.com. They were a 5th the cost of the ones at home depot and audio stores. My HDMI wallplate was $8. Everywhere else has them for $40+.
As for the best terminations. I use banana plugs, solder the connection (to prevent oxidation) and then use heatshrink tubing to conceal the connection. Spades are a good option too and generally provide a stronger connection when screwed down. They also make locking banana plugs.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
Similar Threads
DIY Cable and Cable Tools Sonnie Remotes | Cables | Accessories 5 09-23-08 04:45 PM
Has anybody bought cables from Signal cable or Colbolt cable??? Jay C Huskers Remotes | Cables | Accessories 0 02-04-07 11:28 AM
Good Sub Cable w/Cheap Y-Cable... Lose Quality? baniels Remotes | Cables | Accessories 4 12-07-06 10:22 AM
DIY Power Cable Nick77 Remotes | Cables | Accessories 0 11-14-06 04:11 PM
Cable building? toecheese Remotes | Cables | Accessories 12 05-27-06 04:22 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
