| Home Theater Design and Construction New Home Construction - How big should the A/V room be?Discuss New Home Construction - How big should the A/V room be? in the Home Theater Installation and Systems forum; New Home Construction - How big should the A/V room be? I'm planning on adding a theater room to a new house I am building. The room as currently designed is ... |
| | #1 (Link) | |||
| New Home Construction - How big should the A/V room be? I'm planning on adding a theater room to a new house I am building. The room as currently designed is currently 8' x 11' x 23' on concrete slab but I have some flexibility in that size. I've done enough reading now to think that I should follow a plan something like this for designing my new room. 1. Pick a room dimension that provides better modal qualities. I've seen some standard ratios posted and 1 x 1.4 x 1.9 is one I've seen that would give me a room 8' x 11.2' x 15.2' or maybe 1 x 1.6 x 2.33 which would give me 8' x 12.8' x 18.67'. Given the other house dimensions it's harder to make the room wider than it is longer. It probably wouldn't be hard to raise the ceiling a little. Are there other dimensions that might work well in this situation? 2. Assume the first row of seats are 38% of the distance from the front and the second row of seats 76% of the distance from the front wall. 3. Pick a screen size and resolution that is appropriate from that distance. Any thoughts on that general approach? | |||
| | #2 (Link) | |||
| Re: New Home Construction - How big should the A/V room be? Given how much you'd have to shorten the room to get one of the 'perfect' dimensions (that aren't terribly perfect anyway - all rooms still have modal issues), I'd take the extra space any day. It opens up a ton of other options and much more flexibility in seating. Try 38% and 62% for seating locations - or 62% and wherever the back row falls (as long as you keep it away from the back row). Seriously, don't get too hung up on perfect dimensions -there aren't any. All you can do is avoid particularly bad ones. What you've described isn't bad though making the ceiling a bit higher would certainly help. Bryan | |||
| | #3 (Link) | ||||
| Re: New Home Construction - How big should the A/V room be? Quote:
![]() ![]() and is okay to me (it was a bonus room in the house).You have to consider what furniture, equipment, lay out, etc... you wil be using here. I'm sure you want to have a nice set up. Like one of the post said: "Every room will have to be treated to have a great response" ... you will always have to use accoustical treatment. If you can, make the room bigger do it; if in the future you want to get extra furniture or change what you have, you won't be limited by the size of the room ..... ![]() ![]() ![]() | ||||
| | #4 (Link) | |||
| Re: New Home Construction - More Questions Thanks guys. This has been very helpful. Unfortunately every answer leads to more questions. Some Now I'm looking for some thoughts on how to allocate my budget. Since I realize my personal preferences have a big impact on any advice I'll give you some background. I'm 48 and my wife is 50. We're building this house to die in but who knows. I've got a BSEE degree and a Masters in Telecom Management but I've gravitated more to the business side of Engineering and am more comfortable discussing foreign currency than Fourier transforms. When I buy things I want them to be high quality but not gold plated. I am absolutely not an audiophile. My audio card and speakers are always the cheapest part of my computers. I'm more likely to listen to NPR than the radio and even less likely to listen to a CD. For this theater I want to hear the sound from all the directions the movie company intended but I'm unlikely to notice if the pitch is off. I'm considered borderline hard of hearing so I do think some sort of equalizer would be valuable so I can adjust certain frequencies. Since my wife has no hearing problems I'm wondering if there is something where I can preset one arrangement for me and one for her (and probably one for when she comes in a tells me it's too loud). ![]() I am more interested in the video quality. I want to watch movies, TV, football games and play computer games (strategy not first person shooters). I'm thinking of buying a 1080p system so it will support the latest video/computer graphics 3 to 5 years from now but I don't want to waste my money either. When I buy a new computer I generally make sure I have the latest CPU architecture but I usually buy something a couple of steps below the highest processor speed. I'm not a do-it-yourselfer. I want to do my research up front and tell the builder to build it the way I want. I read the thread on painting the wall for a screen. If I can tell the builder to prep the wall this way and use this paint for $500, buy a screen for $1000, or paint the wall myself for $200 I'm going to tell the builder to paint the wall. If the screen only cost $600 I'm probably going to install the screen so I can avoid potential fights with the builder over the quality of the paint job. For furniture I'm leading toward 2 rows and seating for 6. The room will be dedicated with no windows. I'm somewhat concerned about soundproofing. It will be a one story house with the bedrooms on the opposite side of the house past the kitchen and great room. I don't want to worry about the neighbors if my 16 year old son turns the volume up too loud. The exterior walls will be brick with 2x6 construction and an R-25 insulation package. Hopefully that gives somebody an idea of where I'm coming from. Assume I have $8-10,000 to spend for everything in the room including furniture, video, sound, wiring, remote controls, installation, calibration, soundproofing and anything else I haven't thought of. I'd really appreciate any thoughts on how I should expect to allocate that budget. | |||
| | #5 (Link) | |||
| Re: New Home Construction - How big should the A/V room be? Keep as much space as you can. I wouldn't even think about splayed walls. To get any real benefit,you need at least 1" per foot of length on each wall. That would make the front 46" narrower or about 7'. That causes issues with screen size, speakers too close to walls, etc. A decent 1080p projector will shoot between 40 and 50% of your budget. But, that's OK if that's your goal. Just be realistic about the audio side and how many seats you'll be able to buy - not to even mention the cost of a contractor to actually build this. Bryan | |||
| | #6 (Link) | |||
| Re: New Home Construction - How big should the A/V room be? OK, scratch the 1080p. I don't think I want to consume that much of my budget on the video. As for the construction costs I'm not counting that since it's part of the new home I am building. Since I'm still negotiating with a couple of builders I can still make changes to basic structural elements pretty easily. I've attached a drawing of the house plan I'm starting from. If I need a foot here or there I can increase the home size or steal a little space from the kitchen/great room. Construction costs are about $55/sq. ft here so making the home a little longer or wider wouldn't be too expensive. By the same token I can make it a foot shorter and have about $600 more for something else. That's why I'm trying to 'right-size" the room. | |||
| | #7 (Link) | |||
| Re: New Home Construction - How big should the A/V room be? After some more reading tonight I wonder if I really need to scratch the 1080p or not. Since we haven't even decided on a contractor it will probably be Christmas before this house is finished. Would anyone care to guess where the 1080p pricing might be in 6 months? Do projector prices tend to follow PC pricing with significant sales the day after Thanksgiving and sometime after Christmas? | |||
| | #8 (Link) | |||
| Re: New Home Construction - How big should the A/V room be? They may fall a little but they're already fallen a lot in this last generation. As for the room size, if you need the money, shortening up to 19' wouldn't be a bad thing but would put more of a crimp on proper seating if you want 2 rows. Bryan | |||
| | #9 (Link) | ||||
![]() ![]() ... if you don't have one, It will be a good idea to start planning one.After looking at the drawing, it seems to me that the room will be narrow and long (mine is 9 x 18 inside dimensions, I'm not counting the thickness of the walls); I have two rows of seats and the space between the wall and the seat is only about 11" in one side only .... in your case it will be around 18" each side to have it centered on the room (depending on the size of the seats ![]() ....I think a wider room will be necessary .....just my opinion.Do you need a projector???? .... What about plasma, LCD, DLP???? .... maybe you can save some money there. I have a 67" DLP, with todays price it costs around 2800.00 .... but if you want a projector, you can also consider a used one to save some money ![]() ![]() ![]() | ||||
| | #10 (Link) | |||
| Re: New Home Construction - How big should the A/V room be? John. the ancient Greeks found a room ratio the length 1.5 times the width and ceiling as high as possible to obtain the best acoustics, that still applies to today . As to a screen , paint your plaster , (dry wall) it saves you a fortune , and there is little difference in quality between that and a 2000 dollar screen , I know because i have done so , and so have my friends . Put most money into good speakers , acoustic treatment to the room can be added later anytime . Get a cheap projector as the projectors are getting better and cheaper every day , latter you can get a crash hot one for bugger all . Hope my suggestions are helpful to you John . Kind regards , Alan . ![]() | |||
| | #11 (Link) | |||
| Re: New Home Construction - How big should the A/V room be? John, I'm not sure if you've seen this room mode calculator or not. You should definitely download and play with it, noting the various "golden ratios" it suggests. While it's not hugely important to stick to these ratios, the calculator is also great for room volume: compare yours to the suggested minimum and you'll get an idea of where you stand. You might also like to check out this viewing distance calculator. View our home theatre project at the Wychwood website. Comments welcome! | |||
| | #12 (Link) | |||
| Re: New Home Construction - How big should the A/V room be? I only have one comment about the screen: I would not paint a screen unless it fell exactly on one horizontal drywall piece in the middle. Drywall and plaster is almost impossible to get perfectly flat. There are usually seams with mud buildup. All this could cause a "speedbump" in the screen, which once you notice, you will not be able to un-notice. If the screen was across only one board laid horizontally, none of the image would be on the seams, so it would probably be okay, so long as the screw holes were filled right. And I have never seen a perfectly flat all-plaster wall. What looks flat at a glance and what is flat enough for a screen are very different. That all being said, I have a $500 fixed frame screen (Greywolf II) and love it. The pull down versions are much cheaper. So you don't have to spend a fortune to get a good screen. Best of luck. | |||
| | #13 (Link) | |||
| Re: New Home Construction - How big should the A/V room be? Agreed. Painting sounds like a great idea and it's relatively cheap - but the imperfections can be really annoying. That said, you can DIY a screen pretty reasonably using matieral from Carada or others. If video is your primary concern, then I wouldn't scrimp on the screen. The best PJ in the world won't help if your projecting onto a sub-par surface. Bryan | |||
| | #14 (Link) | ||||
| | #16 (Link) | |||
| Re: New Home Construction - How big should the A/V room be? I did want to try it when I got my projector, I just had too much on my plate and wanted to just buy it and be done. Maybe sometime in the future. It probably would not have worked in my case as well. I ended up with the Greywolf II screen because I needed the 1.8 gain to get a good picture with my size and lighting. The 1.0 screen I had as a loaner washed out quickly with any room light (my wife and I like to read or do other chore/hobby things while watching TV, so being able to see a good picture with the room lights up was a must). The 1.8 gain screen really works well for us. I'm not sure if you can get that kind of gain from painting, but I do remember some expensive paints designed for screens that might work. Name escapes me now, though. | |||
| | #17 (Link) | |||
| Re: New Home Construction - How big should the A/V room be? I think this is what you're referring to. http://www.goosystems.com/index.php?cont=home Notice in the application directions that they're recommending sanding to a smooth surface prior to application. Bryan | |||
| | #18 (Link) | |||
| Re: New Home Construction - How big should the A/V room be? I appreciate all of the suggestions. I've been giving it a lot of thought and here's where I'm at for now. I'll probably buy a screen. I'm a little like Anthony in that I've got a lot on my plate and I rather just have it done. Having the builder paint it probably wouldn't save me much. A paint color change is +$200 and smooth walls are another upgrade cost. After looking at some theater seating sizes I've decided to add a ft to the width. I've learned the standard room height is 9' so that would give me HxWxL of 9x12x23. I've attached a drawing. While I show it as a riser I'm actually going to have the floor lowered in the area near the screen so the height in that area will be more than 9'. That's so the back of the room where the door is will be the same floor level as the rest of the house. I'm trying to keep things in the house wheel chair accessible for when I get old and feeble. Any suggestions on how much I need to lower that area for a second row of seats to have a good view? I've also come up with some budgetary numbers and some preliminary ideas for some of the components of the room. The prices for everything except the cabling and the furniture were from web sites that I think are reputable. The cabling was a price from an audioholics.com recommended system and the furniture was basically what was left from my $10,000 budget. Any additional thoughts on this? | |||
| | #19 (Link) | |||
| Re: New Home Construction - How big should the A/V room be? The screen is WAY too big for that seeting distance - not to mention putting speakers all the way out to the wall which will cause tons of bass response anomolies. Bryan | |||
| | #20 (Link) | |||
| Re: New Home Construction - How big should the A/V room be? Agreed. If BoomieMCT checks in here, he did a similar thing with his theater. He basically filled the whole wall with a screen because he could and had about 6" a side for speakers. While the screen is great, it gave him little room to put speakers. I would only go that big if using an acoustically transparent screen with the speakers all behind it. That being said, reducing to 120" screen would give you more room for speakers. I'm 8' away from a 92" screen and I can't get much closer without seeing pixelation and screen artifacts (720p projector). 1080p would help with that some (i.e. let you sit closer or have a larger screen). That being said, I like the design and seat placement. Good luck and keep us posted! A | |||
| | #21 (Link) | ||||
![]() ... I'm assuming that if you have somebody in a wheelchair you will acomodate them in the back row, Right??.If you make the room wider, you will have more space to a install the speakers, without changing the screen size as the other suggestions .... I have a riser, it is 14" high ... there is a formula to calculate the height (I don't remember where I got it, but it was on the internet and ask you for distance, height of seat, height of the person that will be seated, height of the screen from floor, etc.) .... I think if you lower the front 14" will be okay ... but maybe you need less than that ... ![]() ![]() | ||||
