Screen wall color suggestion - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 18 Old 02-20-12, 12:28 PM Thread Starter
Hi all I'm trying to decide on my screen wall color. First the first phase of my project is going to use a 55" LED Samsung TV. The second phase will have a projector. With that in mind I was thinking about using a color scheme that includes burgundy, caramel, black and brown. What I'm trying to decide is on is whether to do a black or charcoal wall or burgundy. What do you all suggest? Would burgundy interfere with the color of the TV or screen? I would like to pain the ceiling caramel color.
Thanks
DESCypher is offline
post #2 of 18 Old 02-20-12, 04:33 PM
HTS Senior Moderator
Prof.'s Avatar
The Mad Professor
Re: Screen wall color suggestion
The ideal colour is a dark grey..It's completely neutral and doesn't affect the colour balance of the image..
Prof..
Home Theatre...the never ending story!
Prof. is offline
post #3 of 18 Old 02-20-12, 04:40 PM
HTip's Avatar
Is it a dedicated room? Or is your cinema situated in the living room?
If dedicated the best to do is use dark colors. Dark grey (like Prof says) is very good, I've seen good results with dark brown and dark red too. I used black myself.
Stay with dark colours not only on your screen wall, but also on the ceiling, floor and left and right wall until the seating area. From there to the back you can use any color you like. Especially the ceiling is important when using a projector, because of the reflective light.
PS Audio Marantz Oppo ALR/Jordan Velodyne inakustik Furutech JVC Stewart
Chamber of Dreams
HTip is offline
post #4 of 18 Old 02-20-12, 10:15 PM Thread Starter
My room is going to be a dedicated room. I've picked the rugs that I will be using there and they have browns and dark browns with reddish color. My plan is to use colors from it. I can certainly use dark grey as suggested without issue. My goal was to do it as an accent wall and use the darkest color from the rug on the side wall. Then continue the same color as the screen wall on the baseboards. The third color would then be the ceiling where I could use the other dark color from the rug. I suppose I could just follow the same dark grey on the ceiling as well. I have to play with that look.
I got some inspiration from this build http://www.hometheatershack.com/foru...er-cinema.html and like how the caramel type color looked on the ceiling. I wish I had someone who could do a sketch of my room for me and use the colors so I could visualize it.
This is the rug I'll be using and the color scheme I'll be using with a possible grey on the screen wall. http://www.amazon.com/gp/product/B00...01_i00_details
post #5 of 18 Old 02-20-12, 11:19 PM
PTAaron's Avatar
Aaron
I went with Mouse Ears black for my front wall - I love it!
- comments welcome!
PTAaron is offline
post #6 of 18 Old 02-21-12, 01:05 AM
Mark Techer
Prof. wrote: View Post
Absolutely use a dark grey. There is a detailed explanation of this on Joe Kane's Digital Video Essentials - HD Basics (BD). If you don't have that disc and want to see the effects that other colours will have on your picture, cut and paste a nice brightly coloured image into paint, expand the bitmap and change the colour of the back ground. Take note of what it does to the centre image.
Mark Techer is offline
post #7 of 18 Old 02-21-12, 04:05 PM
HTip's Avatar
Mark Techer wrote: View Post
That's a good test. I have the BD and the result is obvious. It looks like the centre image is changing. I thought that he was referring to an black background as the best solution. But I could be wrong. It's been a while since I've used the BD.
Chamber of Dreams
HTip is offline
post #8 of 18 Old 02-21-12, 04:09 PM
HTip's Avatar
DESCypher wrote: View Post
That sounds like a nice color scheme. Visualizing it is a good idea. Maybe someone can accomodate you with that.
Chocolate Thunder Cinema is very nicely done, but I was wondering if the PQ could/would be improved by a darker ceiling. My ceiling is black and almost all light is absorbed and that definitely improves the PQ. I have some pictures with the ceiling not yet fully closed compared to a finished ceiling. I can look them up if you like.
Chamber of Dreams
HTip is offline
post #9 of 18 Old 02-21-12, 04:26 PM
Mark Techer
HTip wrote: View Post
Black works best when your display fills your field of view - [IE large front projection systems. When you are using a smaller screen like a flat panel or RPTV, black may not be the best solution. A dark grey is neutral and will work best when the screen does not dominate the wall. As that simple test shows, other colours tend to bias the colours on screen, so best to aviod them unless your room is only for show with the lights on.
If we look at PTAaron's photo, I would suggest that he has some ambient lights on in the room when watching because in total darkness, the screen is not big enough to be immersive even when seated really close. Whilst the black wall looks neat in the photo, a back lit display with a grey wall will actually work better according to what I've learned over the years. Some RPTVs also need ambient light in the room because they tend to have higher gain screens. The JPK disc does explain this quite well.
post #10 of 18 Old 02-21-12, 10:05 PM Thread Starter
Yes I would appreciate the photos if you can find them. So if I hear you and others correctly it would be best for me to use the grey color in the ceiling also or just use any dark color that fits my color scheme?
Thanks
color , screen , suggestion , wall
