SEATING
* FRONT ROW: 3 Curved Berkline 45003 Black Leather Motorized Recliners
* BACK ROW: 4 Curved Berkline 45003 Black Leather Motorized Recliners
SPEAKERS
* CENTER: M&K S-5000 THX
* FRONT LEFT/RIGHT: M&K S-5000 THX
* FRONT WIDE LEFT/RIGHT: M&K SS-150 THX
* FRONT HIGH LEFT/RIGHT: M&K SS-150 THX
* SURROUND LEFT/RIGHT: M&K SS-150 THX
* BACK LEFT/RIGHT: M&K SS-150 THX
* SUB: M&K MX-350 THX (Looking to add a 2nd Sub)
ROOM DIMENSIONS
* BEFORE WALLS: 23'7.25" Deep x 17'9" Wide (excludes 10'7" x 2'7" entryway)
* NOTES: The theater is being constructed in part of our unfinished basement. There is a 23" drop in the basement to allow for stadium seating.
* SHORTEST CEILING HEIGHT BEFORE CONSTRUCTION: 8'10"
* TALLEST CEILING HEIGHT BEFORE CONSTRUCTION in Drop Down area: 10'9"
HARDWARE
* RECEIVER: Onkyo TX-NR3008 (9.2)
* AMP: Emotiva XPA-5
* BLU-RAY PLAYER: Cinemar MLP-1000 Digital Movie Player (BluRay/DVD)
* STORAGE: Cinemar MLD-4000 12 TB Mass Storage Server
* PROJECTOR: Panasonic PT-AE4000U
* MOTION: D-Box Motion Platform for front row (3 Chairs)
* SCREEN: 140" Wide (152.1" Diagnol) 2.35 AT Screen (Seymour AV)
* USER INTERFACE: Cinemar's MainLobby / MLServer / DVDLobby
* LIGHTING CONTROL: Insteon via MainLobby
* THERMOSTAT CONTROL: via MainLobby
* INTERCOM: Not sure yet - most likely go with Russound
SOUND PROOFING
The room above the theater is a nursery and office. One of the rooms next to the theater is a furnace room. So it's important to keep the sound out of the rooms above and prevent sound coming in from the furnace room.
Current plan of attack is to use two layers of 5/8" drywall and Green Glue with sound absorption clips. Staggered stud walls will be on any framed walls.
* Minimum 1-3/4" Solid Core Door with automatic door bottom.
PAINTED STAR CEILING
* This may be added later in the soffit; however, I will definitely plan for it.
UNFINISHED BASEMENT AREA
MY ORIGINAL PROPOSED THEATER DESIGN (Top View)
MY ORIGINAL PROPOSED THEATER DESIGN (Side View)
LATEST THEATER DESIGN (Top View)
LATEST THEATER DESIGN (Side View - RESERVED)
LATEST THEATER DESIGN (3D View)
FABRICS, CARPET & PAINT INFORMATION
COMPOSITED 3D IMAGE WITH ACTUAL PHOTO [There is an angled divider. The Left Upper Area is the actual photo, the right lower area is 3D]
FINAL ACTUAL PHOTO WITH NIGHT SKY MURAL STAR CEILING:
LED MOVIE POSTER DISPLAYS CURRENTLY PLAYING MOVIE AND ACTUAL START / END TIMES USING CINEMAR'S MAINLOBBY SOFTWARE
CURRENT STAGE OF CONSTRUCTION
* Finishing Mouldings on Columns
* 03.19.11 - Construction Lumber arrived and moved into Basement
* 06.20.12 - Nearly Finished Painting
* 08.13.12 - Construction Completed
* Working on Room Acoustics, Picture, Automation User Interface
SPEAKERS
ROOM DIMENSIONS
HARDWARE
SOUND PROOFING
