PTAaron's Movie Room/Game Room/Bar - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
 94Likes
post #21 of 461 Old 03-08-12, 02:47 PM Thread Starter
PTAaron's Avatar
Aaron
Re: PTAaron's Movie Room/Game Room/Bar
The following weekend (first weekend of February) I decided to paint the front wall. I had been planning on doing a dark grey color - but in a shocking turn of events my wife (who has consistently complained that she doesn't want me to make the room TOO DARK) said "Shouldn't you just make it black?" I immediately went to Home Depot and bought a can of Mouse Ears black in eggshell finish!
I ended up spray painting the outlets with several coats of flat black paint after finding out that a brush does not cover them well...
I patched (poorly) the hole where my previous speaker distribution panel was, and gave the front wall the first coat of paint...
Lets just say that if you want BLACK - Mouse Ears is about as black as you can get! Holy ! LOL!
Note the white panel still on the wall - I got lazy... I didn't move the TV earlier when I had the spray paint out - so that panel didn't get painted. I decided to just paint around it. It will never be seen anyway - and if it ends up bothering me I can take some spray paint to it then.
...I ended up doing a second coat the next day because I was seeing quite a few small white specks showing through.
Quick shot of my spray painted outlet covers:
The room with the lights on full - looks dark because the camera set the exposure for the TV... but you get the idea:
You can see I also painted the door to the closet.
Lights dimmed a bit...
.... note that my "behind the TV bias light" no longer illuminates the wall AT ALL... that Mouse Ears paint just sucks up all the light... so I ended up removing it from the setup.
- comments welcome!
PTAaron is offline
post #22 of 461 Old 03-08-12, 02:55 PM Thread Starter
PTAaron's Avatar
Aaron
I also did some playing around and made myself this little poster displaying the logos of all the equipment in the room:
It now hangs above my light switch panel:
Here is a recent shot of the entire room:
...and that pretty much brings us up to date.
I now have everything controlled via RF using my Harmony 1100 - and I have used a little "work around" to make it so I can program macro-like functions... so here is just a little clip demonstrating how I have it set up:
- comments welcome!
PTAaron is offline
post #23 of 461 Old 03-08-12, 03:17 PM Thread Starter
PTAaron's Avatar
Aaron
Things left on the short term "To Do" list:
1) Remove the mirrors from the left wall of the movie room and patch or replace the drywall.
2) Paint the side walls of the movie room "Sorcerer's Hat" blue.
3) Start the project to rebuild the bar!
I am looking at options to get the mirrors down - and I've come to the conclusion that I probably can't remove them without destroying either the mirrors, the drywall, or both. They are held in place with quite a bit of construction adhesive - so I thought I might be able to use a wire to saw through, but I can just see that going wrong in so many ways! I'm basically stalling on this part of the project and hoping a better idea comes to me.
The bar rebuild project is really exciting - and we should have had it done by now, but we had to take an "emergency" trip to Las Vegas and used the money we had set aside for the bar project.
The bar project consists of: Removing the current bar top and adding 6-7" to the top of the current bar with drawers on the back side. We will be making a new bar top that is shaped slightly differently to get rid of the extra "lip" that sticks out the right hand side. The bar top will be covered in wood flooring and a layer of clear epoxy with "bar rail" around the edges. The "front" is going to be re-faced with wood and we are debating exactly how that will be done. It may be done with flooring like the bartop, or it may be just plain wood with some molding pieces used to create a design.
Anyway - there you have it! Up to date... so lets hear some comments!!
- comments welcome!
PTAaron is offline
post #24 of 461 Old 03-08-12, 03:45 PM
Sphinx's Avatar
Aaron,
I really like what you have done with you basement. It is really a big step up from what the previous owner left behind.
Out of the box suggestion 1 for the mirror wall: Chalkboard paint. As crazy as this sounds, you could paint over the mirror and create a flat black surface. The new wall would be customizable for artwork, menus, fun for children. You could still get some of the 3M smooth surface adhesive hooks and hank your framed posters. The paint is relatively cheap and if you don't like the results, you can cover it back up until you decide on a new path.
Out of the box suggestion 2 for the mirror wall: use the same construction adhesive to attach sheets of plywood or mdf or drywall or layers. You can then paint, frame columns or hang items. I am not sure how much space you are trying to maintain.
This suggestions maybe be crazy and infeasible, but might get your creative juices flowing.
Sphinx is offline
post #25 of 461 Old 03-08-12, 04:21 PM Thread Starter
PTAaron's Avatar
Aaron
Sphinx wrote: View Post
Aaron,
Thanks for the comments and ideas!
I like the second suggestion the best - that would hide the mirrors and still give me a flat wall that I could paint... hmm...
The "safest" solution I have heard previously was cutting the drywall around the mirrors and trying to remove the mirror+drywall as one unit - but then that involves replacing whole sections of drywall... and I'm not sure I have the skill to do that well.
- comments welcome!
PTAaron is offline
post #26 of 461 Old 03-08-12, 04:36 PM
Sphinx's Avatar
Another random thing I have seen in the past, if your wife buys in on it, is to use a firm roller and paint the ceiling tiles black. The firm roller does not all the paint to fill the textured areas of the tiles and creates an effect of stars in the sky. You could try it on an extra tile and see if you like it. This might be the way to go if you ever decide to use a projector and don't want the white or reflective surfaces of drop ceiling.
Sphinx is offline
post #27 of 461 Old 03-08-12, 04:56 PM Thread Starter
PTAaron's Avatar
Aaron
I like that idea, I had considered painting the frame/rails of the drop ceiling black just because I think it would look pretty cool - and I had also considered blacking out the first 2 rows of tiles when I was still planning to use my bias light since it was annoying reflecting off the white tiles.
I have 2 spare cracked tiles sitting around, maybe I'll give that a try
- comments welcome!
PTAaron is offline
post #28 of 461 Old 03-08-12, 05:01 PM
HTS Moderator
ALMFamily's Avatar
Joe
Aaron,
Amazing transformation - thanks for sharing all that!
As far as the mirrors, are they at first reflection points? Maybe what you could do is make custom acoustic panels, put furring strips around the mirrors and mount your panels over the top of the mirrors. This would solve your mirror problem as well as starting room treatment.
Just a thought.....
ALMFamily is offline
post #29 of 461 Old 03-08-12, 05:09 PM
tcarcio's Avatar
TC
I agree, great progression. Nice........
tcarcio is offline
post #30 of 461 Old 03-08-12, 05:29 PM Thread Starter
PTAaron's Avatar
Aaron
ALMFamily wrote: View Post
Aaron,
Just a thought.....
Thank you very much!
That was another idea I had been tossing around... The mirrors are approximately 5' high and total 16' in length - so I'm sure that making them into a giant acoustic panel would definitely cover first reflection points on the left wall!
I wasn't sure if that would throw things off since I won' t be able to duplicate it on the opposite wall?
- comments welcome!
PTAaron is offline
movie , ptaaron , room or bar , room or game
