CeilingLink or CeilingMax - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Discuss CeilingLink or CeilingMax in the Home Theater Installation and Systems forum; CeilingLink or CeilingMax Has anyone used either of these products for installing ceiling tiles? http://www.ceilinglink.com/ http://www.acpideas.com/index.cfm?XlinkID=18...
Old 07-27-07, 12:00 PM   #1 (Link)
Alias: chas
Loc: Minnesota
User: #6091
Since: Jan 2007
chas is online now
Old 07-27-07, 12:12 PM   #2 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Re: CeilingLink or CeilingMax
I've not used either of those but the coffered ceiling system looks seriously sweet. I've requested a sample.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 07-27-07, 12:28 PM   #3 (Link)
Alias: chas
Loc: Minnesota
User: #6091
Since: Jan 2007
chas is online now
Are you talking the Evoba stuff at ACP?
Old 07-30-07, 07:30 AM   #4 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
That Evoba stuff looks great. On Bob Vila's Home Again, they showed a coffered drop ceiling install using the OwensCorning equivalent.
It looked great (like an artisan custom cut all the panels and trim) and apparently it's designed for theaters.
I'm a big fan of drop ceilings for a lot of reasons. Running wire is super easy, wiring projectors and the like is easier, and you can easily stuff acoustic panels or more insulation in trouble areas for bass absorption. It used to be that the drawbacks were looks only, but it seems that is no longer a factor.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
