| Home Theater Design and Construction My new theaterDiscuss My new theater in the Home Theater Installation and Systems forum; My new theater Although I have not named it yet, work has begun on the new theater. Currently, as of 08/02/07 we are ... |
| | #1 (Link) | |||
| My new theater Although I have not named it yet, work has begun on the new theater. Currently, as of 08/02/07 we are waiting for the elctrician to complete his work. Pics tes fitting of riser ![]() EQ closet ![]() Scren wall ![]() | |||
| | #2 (Link) | |||
| Re: My new theater More pics, Tore down the riser and stated to insulate Double doors into theater ![]() Screen wall ![]() Kind of a pain insulating the trusses ![]() Termination in EQ closet ceiling ![]() My plans are to use a 3/4 MDF and a 1/4 MDF to bump out the base molding and chair rail. I have linacoustic to go on the bottom half of the side and rear walls. Regular black speaker fabric will cover the linacoustic. The front wall is sill up in the air. I originally was going to use a red velvet curtain all the way across the front, but have since thought of building frames for the top and sides. Last edited by tango; 08-02-07 at 12:30 PM. | |||
| | #3 (Link) | |||
| Re: My new theater And finally, My equipment. I went on a spending spree lately, and bought all new. Outlaw Audio 990 pre Outlaw Audio 7125 amp Denon 1930CI DVD Sony 985DVD 400 disc changer Panamax LC Infocus IN78 DLP pj Carada 118" Criterion Speakers all Paradigms V5' Monitor 11's front CC-390 center (4) ADP-390 surrounds PW2200 sub Chairs are all Berklines 078, black leather- Thanks Roman I ordered all BJC for everything. I have temporarily setup the system in our family room. The speakers were a bit on the bright side but have now mellowed out with the outlaw. I would have hoped for a bit brighter of a system but it's seems pretty neutral | |||
| | #6 (Link) | |||
| Re: My new theater My usher, get out of line and he'll escort you out. ![]() I'll snap some more photos tonight The electrician is MIA. The drywallers are waiting for him to complete his work. I'm hoping is a fast roller coaster ride to the end. Projected first screen date is 09/01/07. | |||
| | #7 (Link) | |||
| Re: My new theater Sweet, keep us posted. New theater builds are the best, but the budget is just a starting point. Nice gear, let me know how the Outlaw performs and what you have had in the past that you are comparing it to. Thanks | |||
| | #8 (Link) | |||
| Re: My new theater Thanks- the outlaw is perfoming great. However I almost sent it back once. I am hoping once the theater gets done the system will sound better. Currently it's in our living room. No AT and high ceilings etc. Before I had an HK AVR7000, great piece of equipment. I mean a great piece of junk. After about 4 years I started have problems with it and HK determined it was unrepairable as they no lnger made the DSP card that went bad. So I lost my money with that one, which I why I went the separate route. My dealer really tried toget me into a Denon 3808 or 4308. I just did not want another receiver. Downside to the Outlaw has got the be the lack of HDMI. However, the theater is to be a dedicated one for movies only, so I'm not real concerned about multiple sources. | |||
| | #9 (Link) | |||
| Re: My new theater Fantastic! It's really looking good -- do you have drawings for the final setup? I've never seen anyone insulate the spaces within the roof trusses themselves -- is there a reason for that? View our home theatre project at the Wychwood website. Comments welcome! | |||
| | #10 (Link) | |||
| Re: My new theater Mostly for sound. If you don't insulate the trusses you'll actually have an air gap within the trusses. We have stuffed the trusses with an R13 and between the trusses with an R38. I think we will have minimal sound leakage. | |||
| | #11 (Link) | |||
| Re: My new theater Progress has been made screen wall [IMG] [/IMG]back of theater ![]() double doors into theater ![]() family room IMG]http://i197.photobucket.com/albums/aa71/utopia1273/MVC-008S-2.jpg[/IMG] EQ closet ![]() | |||
| | #13 (Link) | |||
| Re: My new theater Front wall and ceiling will be flat black with panels in the front wall one on each side of the screen and top and bottom. They will be covered in black stretch velvet with linacoustic behind them. Walls are wither going to be dark green or a dark brown. Carpet is medium brown | |||
| | #14 (Link) | |||
| | Re: My new theater Sounds good...I went with dark greyish green walls in my theatre. I think a dark brown carpet would go very well with that.. One tip,if you don't already know about it. If you're going to paint the ceiling flat black, then use the best quality paint you can find..\ Flat black can show up very patchy without lots of coats and a good quality paint.. I used a very dark grey instead, and it works just as well as the black and without any patches and no need for lots of coats.. | |||
| | #15 (Link) | ||||
| Re: My new theater Quote:
May I suggest you to start with a good Sealer/Primer ...(maybe this doesn't apply in your case, but maybe it will help you to avoid the need or a lot of coats) ... ![]() ![]() ![]() When I painted my room I didn't use any primer; I had a semigloss paint and just painted over that ... I din't like the results ... the flat paint shines a little, this means that I have to repaint again using a primer first and then another coat of flat paint ...but this will be sometime in the future ....I have to keep enjoying my movies ... ![]() ![]() ![]() | ||||
| | #16 (Link) | |||
| Re: My new theater Thanks for all the advice. Yes we are going to prime it. And yes we are using high quality paint from Diamond Vogel. That is what all the painting contractors use around here. I was hoping to paint this weekend, but the drying time on the compound is taking a bit longer than expected. The contractors have been there every day this week. Carpet is scheduled for the 24th along with the projector installer that night. It's fine by me as I still have doors to stain and poly. The color is going to be a cappacino color. | |||
| | #17 (Link) | |||
| Re: My new theater-update Well they got the thing textured yesterday. I'll be painting starting tonight and all weekend. Then they will be back on Monday to start trimming it out and the carpet layers and also the projector people willbe in on the 24th. Lots to do- I still have to put my riser together. It a good thing I pre-cut everything. I'll snap some photos when I get a chance. | |||
| | #19 (Link) | |||
| Re: My new theater no stage being planned at this point. I took last week off and got the whole thing done. They are laying the carpet today. I took some pics this morning but they turned out really bad son I'll snap some more tonight. I ended up going with Dig It. It sort of a medium brown. Got my center channel stand built yesterday as well. It get some pics of it tonight as well. And finally the projector installer is coming tonight and I have my berklines I have move as well, not to mention setting up all the eq. I'm going to be too tired to watch anything. Also, I need to snap my Carada screen on it's frame. Any tips, I have never installed one? | |||
| | #20 (Link) | |||
| Re: My new theater I'm interested in the idea of stages/proceniums. I've noticed a number of US home cinemas seem to have them, but if I go to the commercial cinema they don't. Why do people install them? Is it to provide a bit of "old world" charm? Or is there a functional and/or psychological reason? View our home theatre project at the Wychwood website. Comments welcome! | |||
| | #21 (Link) | |||
| Re: My new theater-99% finished Well they installed the carpeting last night after a few setbacks and here she is. I still have to make the flanking panels for the sides and top and bottom opf the screen. My center channel stand still needs to be painted as well. But you get the idea. If you ar wondering about the panel in the rear. It's covered in stretch velvet and hides the panel and sub panel. ![]() ![]() ![]() Cabinets for the popcorn and butter machines ![]() ![]() | |||
| | #24 (Link) | |||
| | Re: My new theater Very nicely done tango...It's looking great.. ![]() Nice colour choice all round..the chairs look great and I love the timber doors.. The back wall colour looks different than the side walls, or is it just the camera? Also, you were going to have a black ceiling, but it some shots it looks like a different colour.. I can see that you will have many pleasurable viewing hours... | |||
