running speaker wires - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Discuss running speaker wires in the Home Theater Installation and Systems forum; running speaker wires whats the best way to run speaker wires inside walls so you dont see them?...
Old 10-22-07, 10:46 PM   #1 (Link)
New Member
Alias: bonj87
Loc: joliet
User: #5568
Since: Jan 2007
bonj87 is offline
Old 10-22-07, 11:04 PM   #2 (Link)
Loc: Lower Alabama
Sonnie is offline
Re: running speaker wires
Hi joliet and welcome to the Shack!
What kind of walls do you have and can you access the attic above or below the walls where you want to run the speaker wire?
Sonnie
Old 10-23-07, 08:27 AM   #3 (Link)
New Member
Alias: bonj87
Loc: joliet
User: #5568
Since: Jan 2007
bonj87 is offline
i have a new home.. drywall walls.. no plaster.. new house built last year
yes i have access to the attic and the basement, which is un finished.. the area above the home theater issue is the 2nd floor, which i dont have access to run wires that way.
Old 10-23-07, 10:04 AM   #4 (Link)
Alias: Brad
Loc: Torrance, CA
User: #2491
Since: Sep 2006
bhorstkotte is offline
bonj87 wrote: View Post
The best way is the path of least resistance:
  • if you have an attic above your ceiling, run them up through the wall cavities (unless the drywall is on already, and there is fire blocking, in which case that's going to be difficult unless you make more holes in the walls temporarily to drill through the fire blocking); drill through top plate, making sure its accessible from above
  • if you have a crawlspace or basement below, run them down through the wall cavities (same issue with fire blocking if its there); drill through sole plate - make sure the sole plate doesn't sit right on top of the concrete foundation, if so, you'll need a different route
  • if you don't have access from above or below, you can run them through the cavity behind crown molding or baseboards
  • keep speaker wire runs away from AC wiring as much as possible - I had to cross over a few wires, and its not a problem, but if you run them right next to each other, you may have interference problems
  • use in-wall rated speaker wire (CL2 /CL3)
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
Similar Threads
Hiding speaker wires? rkruz Home Theater Design and Construction 14 01-09-07 08:26 AM
ssabripo's DIY Speaker cables Tutorial (cat5e based): Audiophile wires on the cheap! ssabripo Remotes | Cables | Accessories 3 11-03-06 03:23 PM
Cable-Free Surround Sound: From Wireless Speakers to Hiding Speaker Wires Chris Boylan Home Theater, Audio and Video News 0 10-18-06 07:51 PM
Up and running.... garymck DIY Subwoofers 4 07-26-06 10:44 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
