Increasing the sense of height in a vertically challenged HT:) - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Discuss Increasing the sense of height in a vertically challenged HT:) in the Home Theater Installation and Systems forum; Increasing the sense of height in a vertically challenged HT:) Hi, I'm about to build a theater in my basement, and was wondering if anyone had any ideas for increasing ...
Old 11-05-07, 11:22 AM   #1 (Link)
Alias: tc
Loc: Edmonton
User: #1410
Tristanc1 is offline
Hi,
I'm about to build a theater in my basement, and was wondering if anyone had any ideas for increasing the perceived height of the space? I have lots of width, and length(13X24) but only a few inches over 7 feet in height. I won't be using the whole length of the room either, probably only 18 feet or so. I'm still reading over information about the 'optimum' size on Ethan's sight, so the ultimate length is still being determined.
Any ideas? I really like the look of dark ceilings, and have been in a few theaters with dark, or completely black ceilings and if anything it made the room look higher which I wasn't expecting at all. I also like the benefits of a darker ceiling in regards to reflected light from a projector. Which could be an issue for my theater aswell, seeing as the projector will be firing closer to the ceiling than in most theaters with 8+ feet right? However i've only seen the black ceilings in theaters that are gargantuan to begin with, so i'm not sure if it would be a good idea in the space that I have....
Any ideas would be greatly appreciated
Tristan
Old 11-05-07, 12:36 PM   #2 (Link)
Alias: Ethan Winer
Loc: New Milford, CT, USA
Ethan Winer's Avatar
User: #1679
Ethan Winer is offline
Lightbulb Re: Increasing the sense of height in a vertically challenged HT:)
Tristanc1 wrote: View Post
Black will make the room look higher, but what really matters is making the ceiling higher acoustically. This is done with absorption.
--Ethan
RealTraps
Old 11-05-07, 01:07 PM   #3 (Link)
Alias: tc
Loc: Edmonton
User: #1410
The absorption thing is good to hear actually, thanks Ethan. What I had thought of doing (bare with me it's difficult to explain) is having drywall on the sides of the ceiling, maybe coming 1 or 2' into the room on either side, then running AT black fabric down the center of the room covering a gigantic absorber. Maybe even in some kind of pattern aswell, perhaps running straight for a few feet and then connecting to a circle or some other wider shape to catch the first reflection points on the ceiling from the front 3 speakers... Just throwing ideas around, not sure if this would be advisable or not. If I did that i'd be sacrificing sound proofing though, although in my situation i'm already aware i'm not going to achieve something ideal, so it's just a matter of balancing the trade offs I suppose
Tristan
Old 11-05-07, 01:53 PM   #4 (Link)
Alias: tc
Loc: Edmonton
User: #1410
Here's what I have right now, and kind of what I was thinking of doing again for the ceiling. It doesn't quite work to make the room look much bigger, thinking I might need more black down the center and perhaps a better lighting arrangement..... It's also partially demo'd at the moment so that's why it looks like c$@%
Old 11-06-07, 11:41 AM   #5 (Link)
Alias: Ethan Winer
User: #1679
The best place for bass traps, which all rooms need, is in corners. So I'd skip the drywall and use insulation in a thin wood or metal stud frame covered with fabric. You can make any shape you'd like for appearance, but avoid sheet rock.
--Ethan
RealTraps
Old 12-15-07, 06:53 AM   #6 (Link)
New Member
Alias: GT
Loc: Atlanta
User: #14095
Since: Dec 2007
gary thomas is offline
Our basement started with a 9' ceiling, but we wanted to add insulation & a bit more mass to separate the basement from the main level. We had our contractor build a new 8' ceiling, but not attach it to the old ceiling. We insulated the gap between the new & old ceiling. To maintain some of the height, we added a tray w/ hidden rope lighting. It's on a dimmer along with a DIY lighted movie poster box. The room is painted midnight blue & the tray is a lighter beige. We feel it really helped maintain the impression of height.
Old 12-15-07, 04:48 PM   #7 (Link)
Shack Helper
Alias: Prof.
Loc: South of Adelaide
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is offline
Anything you put on the ceiling will only emphasize how low height the ceiling is..
If you want to give the illusion of the ceiling being higher than it is, you need long vertical items on the side walls..
For example, floor to ceiling curtains or long narrow acoustic panels down the side walls and across the back..
I had a similar problem with my 7'6" ceilings, so I hung grey suede curtains floor to ceiling, from the screenwall back about 7' along the side walls..and a floor to ceiling curtain on the back wall.
The ceiling was painted a very dark grey..
It really lifted the perceived height..
Old 12-15-07, 10:55 PM   #8 (Link)
Alias: Zip
Loc: Canada
MatrixDweller's Avatar
User: #10408
Since: Jul 2007
MatrixDweller is online now
The Prof is right. You've probably heard that tall women shouldn't wear vertical stripes or over weight people shouldn't wear horizontal stripes. Thin vertical stripes will make something look taller. I'd avoid chair rail or wainscoting. 6" pillars or buttresses and/or a series of 1'x6' foot acoustical treatments might make the room look taller.
I think you've done a great job with your ceiling with the faux recessed area in the middle. That actually makes it look like a void. I hope you don't mind but I'm going to copy that idea in my current construction (my ceiling is only 7¾ feet).
If I had the time and money I'd do a fiber optic night sky.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
Similar Threads
Constant Image Height (CIH) projectors: still rare? John Simpson Home Theater Projectors 4 06-18-07 07:31 PM
John Cleese Letter (Sense of humour test) Fincave Chat Box 1 07-02-06 12:52 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
