Ellis Family Retirement HT: Go big or go home - Page 21 - Home Theater Forum and Systems - HomeTheaterShack.com
 17Likes
post #201 of 793 Old 03-19-14, 01:14 PM
duder1982's Avatar
Re: My retirement Home Theater
Yes adding another hinge or once you get the door hung. Remove 2 screws from the hinge on the jamb side and install longer beefier screws. That way the screws will go into the stud the jamb is mounted to. I myself will be considering building my own door and jamb so I can customize it a little more.
duder1982 is offline
post #202 of 793 Old 03-19-14, 05:18 PM Thread Starter
ellisr63's Avatar
Ron
bpape wrote: View Post
I would think it would be OK. If more support is needed, adding another hinge would be the best way to go.
duder1982 wrote: View Post
My friend and I are planning on adding wood to the outer side (side facing away from the HT) skin of the door and adding acoustic treatment to the other side of the door (HT hallway side) for one of the doors. The other door will get acoustic treatment to both sides of the door. Does this sound like it will be ok?
Ron
My Home Theater
Yamaha CX-A5100, (3) JBL 2360A/EV DHA-1s, (3) 1/4 Pie bass bins, (2 pr) JBL 8340As, (2 pr) JBL 8320s, PS3, XBox One, (2) Intel NUCs, Redmere HDMI cables, Monster Signature HTPS7000, (2) Furman Power Conditioners, (2) DTS-10 subs, Panasonic AE8000, SeymourAV 180 (195" diag) scope screen, Darbee Darcet, Panamorph UH-480 lens, (2) Crest Audio 2208, Yamaha XM-4080 & P7000s, (2) MiniDSP DDRC-88M, Oppo UDP-203
ellisr63 is offline
post #203 of 793 Old 03-20-14, 01:08 AM Thread Starter
ellisr63's Avatar
Ron
I have been looking at door seals... One thing I noticed is they are only good for 40-50 STC. If you are building your room for a 60 STC are you wasting your money since the doors will be lower?
Ron
My Home Theater
ellisr63 is offline
post #204 of 793 Old 03-20-14, 07:06 AM
duder1982's Avatar
ellisr63 wrote: View Post
Thats some what, what my idea was so I hope so.
post #205 of 793 Old 03-20-14, 09:18 AM
HTS Moderator
ALMFamily's Avatar
Joe
Ron,
I added the automatic door jambs to my entry door. I think besides increasing the STC rating of the door, the added benefit was that it made the room more pressurized which really helped the LFE.
ALMFamily is offline
post #206 of 793 Old 03-20-14, 12:59 PM Thread Starter
ellisr63's Avatar
Ron
Thanks for the responses.
I think we will add MDF to the door skin on the theater side of the outer door... I am not sure if we should do it on the other side of the door as it is 5' from a 7400 gallon indoor pond, and I am worried about MDF and moisture. I am also thinking of making acoustic panels to match the fabric covered room panels for the doors.
Ron
My Home Theater
ellisr63 is offline
post #207 of 793 Old 03-21-14, 02:47 PM
MrAngles's Avatar
I need 5-6 pails... My wife is really getting on me for spending all the money on the HT, and I need to get it done ASAP before she really gets mad at me.
5-6 pails is an awful lot... it should still only be $1200 for 6 pails though unless the price has gone up, definitely not $2k if you're buying from the soundproofing company.
You could consider only doing double drywall on the interior side of the theater walls instead of both sides, or using only a tube and a half or one tube of green glue on each panel, or use two tubes per panel on the ceiling and only one tube per panel on the walls. Some green glue is better than no green glue at all. Are you still planning to do a layer of OSB plus two layers of drywall on the walls? That's really pretty overkill. Two layers of drywall or one layer of OSB + one layer of drywall will be plenty.
MrAngles is offline
post #208 of 793 Old 03-21-14, 02:49 PM Thread Starter
ellisr63's Avatar
Ron
I am going to look at what doors my friend has for me in the morning... I think I might go with steel doors if they are massive enough, and then add the MDF to them. I am debating on buying the seals for the top, and sides of the doors too or just making some out of wood. The reason for this is $$$. I was browsing online and to do the seals all around the door it was like $500 per door.
Any suggestions or comments?
Ron
My Home Theater
ellisr63 is offline
post #209 of 793 Old 03-21-14, 02:55 PM Thread Starter
ellisr63's Avatar
Ron
MrAngles wrote: View Post
4 pails is $1229 shipped. So 6 pails would be in the $1800 range from the Soundproofing Company. I am out of cash at the moment so we are doing what we can. If I end up getting the cash for it before we make it to the second layer I will go the GG route still. I fully anticipate it being a month or so before we get to that stage as we will only be working a day or 2 per week on it.
We are only doing OSB, GG, Drywall on one side of the walls already. The estimate was for doing 2 tubes per sheet... I know that some people do 1 tube and some do 3 tubes per sheet.
Ron
My Home Theater
ellisr63 is offline
post #210 of 793 Old 03-22-14, 12:11 AM Thread Starter
ellisr63's Avatar
Ron
I picked up another matching power recliner for the front row which brings the front row to 3. We are thinking of making the front row curved and then also looking for a modular couch for the second row that would also be curved.
We are still trying to work out the HVAC cold air intake... We are thinking of getting some 8" flex to run in a soffit behind the screen and dump it into the main part of the house where the cold air intake is for the rest of the house. What we are thinking is to zig zag about 50' of the flex pipe in the soffit. Does that sound like it will work?
Ron
My Home Theater
ellisr63 is offline
home , retirement , theater
