Ellis Family Retirement HT: Go big or go home - Page 22 - Home Theater Forum and Systems - HomeTheaterShack.com
 17Likes
post #211 of 795 Old 03-22-14, 09:11 AM
duder1982's Avatar
Re: My retirement Home Theater
If your talking return for you hvac. I don't why it would hurt, we have returns in all the upstairs rooms and they are probably over 50' long. I would just try to keep it as strait as possible.
duder1982 is offline
post #212 of 795 Old 03-22-14, 11:12 AM Thread Starter
ellisr63's Avatar
Ron
duder1982 wrote: View Post
The idea of a long return line is to try and absorb any noise from exiting the room to the other areas of the home. I was told to do it in a "S" shape so the sound waves will hit the sides of it and cancel. I was just not sure if it will be enough to cancel all the sound from exiting.
Ron
My Home Theater
Yamaha CX-A5100, (3) JBL 2360A/EV DHA-1s, (3) 1/4 Pie bass bins, (2 pr) JBL 8340As, (2 pr) JBL 8320s, PS3, XBox One, (2) Intel NUCs, Redmere HDMI cables, Monster Signature HTPS7000, (2) Furman Power Conditioners, (2) DTS-10 subs, Panasonic AE8000, SeymourAV 180 (195" diag) scope screen, Darbee Darcet, Panamorph UH-480 lens, (2) Crest Audio 2208, Yamaha XM-4080 & P7000s, (2) MiniDSP DDRC-88M, Oppo UDP-203
ellisr63 is offline
post #213 of 795 Old 03-22-14, 03:56 PM
duder1982's Avatar
OK then disregard my input, I thought you were asking from a hvac performance stand point. This is good to know, as this may be what I need to do to get the sounds that travel through out the air ducts to quite down a bit.
post #214 of 795 Old 03-22-14, 04:20 PM Thread Starter
ellisr63's Avatar
Ron
No problem... I should have explained it better.
Ron
My Home Theater
ellisr63 is offline
post #215 of 795 Old 03-27-14, 11:33 PM Thread Starter
ellisr63's Avatar
Ron
Today we got one of our solid core wood doors hung... It was a 36" wide 2" thick door. We made our own framework for the door out of 2x6s, and made the door seals for the top, and sides out of 2x4s. The bottom seal will be purchased. We still have to get the foam for sealing the door but at least we have a nice wide surface to use as a door stop in the frame and to seal against.
Now I am looking to see where I can get the nice long bar style handles they have on the Theater doors, and also a door closer. They short hallway between the 2 doors is inclined just like the Theaters do too. I hope to have some more pics up this Sunday.
Ron
My Home Theater
ellisr63 is offline
post #216 of 795 Old 03-28-14, 11:04 PM
HTS Moderator
ALMFamily's Avatar
Joe
I seem to recall another build thread where the person had to find longer door handles...if I can remember where I saw it, I will post up a link.
ALMFamily is offline
post #217 of 795 Old 03-28-14, 11:19 PM Thread Starter
ellisr63's Avatar
Ron
ALMFamily wrote: View Post
Thanks, I am going for a commercial style pull handle for one side, and on the other side you will just push the door open. Both doors will have hydraulic door closers on them.
Ron
My Home Theater
ellisr63 is offline
post #218 of 795 Old 03-29-14, 01:54 AM Thread Starter
ellisr63's Avatar
Ron
Question... When you walk into the HT there is a short hallway, the right side wall is attached to the inner room wall but not attached to the outer wall due to the double wall construction. Normally if there was a communicating door right next to the other the space could be caulked as it would only be like 1/4" gap but in our situation there is a couple of inches. How do we seal that area off? Do we get some thick rubber and attached it to each wall?
Ron
My Home Theater
ellisr63 is offline
post #219 of 795 Old 03-29-14, 09:40 AM
duder1982's Avatar
Is it something that will be seen, or covered up with trim. If covered up with trim, I would think great stuff for doors and windows. If not you need a backing like foam rope to shove in there before caulking.
post #220 of 795 Old 03-29-14, 11:53 AM Thread Starter
ellisr63's Avatar
Ron
It will be visible as it is the joint for the hallway wall connecting to the outer door wall. So, when we put the OSB up... We should try and close the gap to as little as possible and then caulk it?
Ron
My Home Theater
ellisr63 is offline
home , retirement , theater
