Ellis Family Retirement HT: Go big or go home - Page 31 - Home Theater Forum and Systems - HomeTheaterShack.com
 17Likes
post #301 of 793 Old 06-21-14, 12:01 PM Thread Starter
ellisr63's Avatar
Ron
Re: Ellis Family Retirement HT: Go big or go home
I solved the LED rope light won't turn off problem!! What I did was get one of these, and plug it into a cheater plug, and then plug the cheater plug into my dimmer outlet... I tried it down to 1% and then turned it off and it works flawlessly!
Ron
My Home Theater
Yamaha CX-A5100, (3) JBL 2360A/EV DHA-1s, (3) 1/4 Pie bass bins, (2 pr) JBL 8340As, (2 pr) JBL 8320s, PS3, XBox One, (2) Intel NUCs, Redmere HDMI cables, Monster Signature HTPS7000, (2) Furman Power Conditioners, (2) DTS-10 subs, Panasonic AE8000, SeymourAV 180 (195" diag) scope screen, Darbee Darcet, Panamorph UH-480 lens, (2) Crest Audio 2208, Yamaha XM-4080 & P7000s, (2) MiniDSP DDRC-88M, Oppo UDP-203
ellisr63 is offline
post #302 of 793 Old 06-23-14, 12:04 AM Thread Starter
ellisr63's Avatar
Ron
Today we got the screen in position, and got the first coat of paint on 3 walls and the ceiling. The La Scala bass bins will be raised to the same height as the center channel.
MLP in the 2nd row.
Ron
My Home Theater
ellisr63 is offline
post #303 of 793 Old 06-23-14, 08:40 AM
J&D
J&D's Avatar
That's progressing nicely. Going to be one fantastic space.
J&D is offline
post #304 of 793 Old 06-24-14, 12:47 PM Thread Starter
ellisr63's Avatar
Ron
Yesterday I got the LED rope lighting up (I still need to get the end caps so I can trim it). Once I get the "T", 90 degree, and end caps I will work on the LEDs around the front screen. When the carpet is installed I will finish the last 3 zones of LED rope lights.
The LEDs look much better in person (these are taken with my Samsung Galaxy Note).
100%
100%
50%
5%
Ron
My Home Theater
ellisr63 is offline
post #305 of 793 Old 06-24-14, 03:24 PM
moparz10's Avatar
Jim
turning out very nicely !
moparz10 is offline
post #306 of 793 Old 06-29-14, 06:07 PM Thread Starter
ellisr63's Avatar
Ron
Today we got the soffits completely painted flat black, outlets installed for the stair rope lights, stage is completely framed and has 2 layers of OSB on the top of the stage. Hopefully the carpet will be installed early this week. Once the carpet is installed we can finish the wall behind the screen (and ceiling). Once that is done we can run the HVAC ducts for the MB, the return duct, mount the projector install the screen, install the speakers, load te rk with equipment and move in the seating. Getting close now...
Ron
My Home Theater
ellisr63 is offline
post #307 of 793 Old 07-01-14, 02:20 PM Thread Starter
ellisr63's Avatar
Ron
I def did not need a hot weather week now.... I just got all the insulation we have stuffed in the stage (I need one more bag to finish it off). Carpet will be installed in the morning, so today will be getting the room ready for the carpet guys. Room is completely painted black except for behind the screen, and the entrance hallway. Hopefully we will be moving equipment in after this coming weekend and start tuning the room.
Ron
My Home Theater
ellisr63 is offline
post #308 of 793 Old 07-02-14, 08:58 AM
Charlie
Your build is looking good.
Since I am replacing a failed hot water heater today, hot water heaters are fresh on my mind.
If yours is approaching end of life (around 9-10 years old) it might be worth thinking about replacing it now and installing the new one in a pan with a drain going to the outside.
I know you already have most of your construction completed, but it would be awful to get everything flooded when the hot water heater dies.
chashint is offline
post #309 of 793 Old 07-02-14, 09:26 AM Thread Starter
ellisr63's Avatar
Ron
chashint wrote: View Post
Good advice... Ours is about 5 years old... It has a pan, and a drain already.
Ron
My Home Theater
ellisr63 is offline
post #310 of 793 Old 07-02-14, 11:09 AM
willis7469's Avatar
Your build is looking good. Since I am replacing a failed hot water heater today, hot water heaters are fresh on my mind. If yours is approaching end of life (around 9-10 years old) it might be worth thinking about replacing it now and installing the new one in a pan with a drain going to the outside. I know you already have most of your construction completed, but it would be awful to get everything flooded when the hot water heater dies.
if your water is hot, why do you need a heater? :Neener: lol
willis7469 is offline
home , retirement , theater
