Ellis Family Retirement HT: Go big or go home - Page 34 - Home Theater Forum and Systems - HomeTheaterShack.com
 17Likes
post #331 of 793 Old 07-20-14, 07:09 PM
phillihp23's Avatar
Re: Ellis Family Retirement HT: Go big or go home
Glad to hear your o.k.
Home Theater System Denon AVR4520CI, Emotiva XPA-5 Gen 2, Polk CSi A6 Center, Polk RTi A9 Front, Polk RTi A7 Front Wide, Polk RTi A1 Front Height, Polk FXi A6 Side, Polk RTi A3 Rear, SVS PB12-NSD x2 Front, SVS PC12-NSD x2 Rear, Panasonic PT-AE7000U, Visual Apex CineWhite 100" Screen, PS4, Dish Hopper, Darbee Darblet DVP 5000.My Home Theater Build
phillihp23 is offline
post #332 of 793 Old 07-21-14, 07:08 AM
HTS Senior Moderator
bpape's Avatar
Bryan Pape
Never a good thing but glad to hear you're mostly OK. Keep an eye on that back and neck - don't let it get too bad and document everything.
Bryan Pape
Lead Acoustician
bpape is offline
post #333 of 793 Old 07-21-14, 11:58 AM
willis7469's Avatar
Glad your ok!(mostly). Definitely keep track of everything. Even the seemingly smallest back/neck injury can stem off into much larger problems. Now, if your theatre was finished, you just might need to add a bunch of extra recovery time! I think I read that theatre seats can actually be quite therapeutic! :wink:
Good luck.
willis7469 is offline
post #334 of 793 Old 07-21-14, 12:44 PM Thread Starter
ellisr63's Avatar
Ron
Thanks, my wife is taking me to get my back adjusted today... We are keeping all the receipts.
Ron
My Home Theater
Yamaha CX-A5100, (3) JBL 2360A/EV DHA-1s, (3) 1/4 Pie bass bins, (2 pr) JBL 8340As, (2 pr) JBL 8320s, PS3, XBox One, (2) Intel NUCs, Redmere HDMI cables, Monster Signature HTPS7000, (2) Furman Power Conditioners, (2) DTS-10 subs, Panasonic AE8000, SeymourAV 180 (195" diag) scope screen, Darbee Darcet, Panamorph UH-480 lens, (2) Crest Audio 2208, Yamaha XM-4080 & P7000s, (2) MiniDSP DDRC-88M, Oppo UDP-203
ellisr63 is offline
post #335 of 793 Old 07-24-14, 11:31 PM Thread Starter
ellisr63's Avatar
Ron
I have been working on building my acoustic panels this week. I keep going to Lowes and cleaning them out of the 1/2" x 3 1/2" poplar for the frame assemblies. So far I have 5 made up (not covered yet though), and enough wood to build another 5 or 6. I hope to have the ones I have built on the walls by this weekend. Hopefully my fabric samples will arrive today so I can order the material for covering them. I am anticipating having 21 acoustic panels in the room (2x4), for the ceiling, and walls. For the bass trap soffits I am using R19 Denim (I think I need about 6 more packs). The Roxul R80 rockwool panels are turning out very easy to build.
Ron
My Home Theater
ellisr63 is offline
post #336 of 793 Old 07-25-14, 06:41 AM
Owen Bartley's Avatar
OJ
You know the rule... Progress pics or it didn't happen! .
How are you feeling now? Hopefully some of the stiffness has gone and you're not suffering any long term issues.
- OJ -
Owen Bartley is offline
post #337 of 793 Old 07-25-14, 08:10 AM
bpape's Avatar
Bryan Pape
Don't go overboard with too many thinner panels and not enough thicker ones and skew the decay time curve.
Bryan Pape
Lead Acoustician
bpape is offline
post #338 of 793 Old 07-25-14, 06:09 PM Thread Starter
ellisr63's Avatar
Ron
Owen Bartley wrote: View Post
Still a little sore but my Chiropractor says I am getting better.
Here are a couple of pics of what I have made today....[IMG][/IMG]
[IMG][/IMG]
The frames are 1/2" x 3 1/2" with a 1"x 1 1/2" inserted on the sides to space the Roxul from the wall.
I keep running out of the 1/2" boards as no one has much in stock.
Ron
My Home Theater
ellisr63 is offline
post #339 of 793 Old 07-25-14, 06:12 PM Thread Starter
ellisr63's Avatar
Ron
bpape wrote: View Post
Should I just use the 2" for the ceiling and behind the AT screen? I could then make up some 4" thick ones for the side walls, and some 8" for the rear wall. All the panels are the Roxul R80 Rockboard... not fiberglass insulation (just to be sure we are talking the same materials).
I ordered 14 yards of the black commando cloth we talked about for behind the screen wall.
Ron
My Home Theater
ellisr63 is offline
post #340 of 793 Old 07-25-14, 09:09 PM Thread Starter
ellisr63's Avatar
Ron
Today I decided to do a little testing... Mind you the door can't be closed all the way, the hallway still needs another layer of Drywall, and outer door has yet to be sealed at all. I put on some music and tested the SPL at the garage door (outside of the theater).... 45db, my wife starts up her new Hyundai Genesis, and it goes to 65db... I walk around to the back of the house and enter the HT... reading is 92db! This from my cell phone app which I don't think is correct because when we watch movies it will never go above 92db... Even at reference levels and this was very loud today! I would be surprised if we were not over 100db. I am very satisfied with the results so far.
Ron
My Home Theater
ellisr63 is offline
home , retirement , theater
