Ellis Family Retirement HT: Go big or go home - Page 36 - Home Theater Forum and Systems - HomeTheaterShack.com
 43Likes
post #351 of 855 Old 08-06-14, 08:37 PM Thread Starter
ellisr63's Avatar
Ron
Re: Ellis Family Retirement HT: Go big or go home
Thanks, the other tape I had heard that was good was Gaffers tape... Not sure if it is better or worse for this situation.
Ron
My Home Theater
ellisr63 is offline
post #352 of 855 Old 08-06-14, 09:52 PM
HTS Senior Moderator
bpape's Avatar
Bryan Pape
Or just double over the edges before you staple it to the frame.
Bryan Pape
Lead Acoustician
bpape is offline
post #353 of 855 Old 08-06-14, 10:34 PM
willis7469's Avatar
+1 for gorilla tape. (If you go that route) I'm building a fallout shelter with it.
willis7469 is offline
post #354 of 855 Old 08-07-14, 12:59 AM Thread Starter
ellisr63's Avatar
Ron
Question Re: Ellis Family Retirement HT: Go big or go home
bpape wrote: View Post
Thanks Bryan,
I don't think I have enough material to double it over... I just had enough to make it to the 1" part on the fold over the frame. Some of the areas were about 1/2".
I got 3 panels completed today... Hopefully I can get 4-5 done tomorrow. Then I will try and get someone to help me with a mirror to see where to install them. Do I do the measurements for each seating position or just the MLP?
Ron
My Home Theater
ellisr63 is offline
post #355 of 855 Old 08-07-14, 01:00 AM Thread Starter
ellisr63's Avatar
Ron
I'll look at the Gorilla tape then if i need to tape it. Do most people tape it if they don't fold it over before stapling?
Ron
My Home Theater
ellisr63 is offline
post #356 of 855 Old 08-08-14, 04:05 PM Thread Starter
ellisr63's Avatar
Ron
I am planning on covering all of the ceiling, and walls with fabric... Something like this , except my acoustic panels would be the only ones sticking out the most.
I was thinking of attaching the fabric to 1/2" x 1" wood and stapling it to it. I would do this for the whole wall, and then attach the acoustic panels to the fabric walls. I was thinking I could do this easily as long as I know where my wood is for attaching the acoustic panels to.
If I do this can I put something behind the whole fabric wall so the material will be more stable, ie if some one pushes on the panel I don't want the fabric to push inward with nothing behind it. What is the way they are normally done? Should I use pegboard, or solid foam insulation panels (with the aluminum foil facing outward)?
Any ideas or suggestions?
Ron
My Home Theater
ellisr63 is offline
post #357 of 855 Old 08-08-14, 04:42 PM
bpape's Avatar
Bryan Pape
I'd just use plywood behind the fabric.
Bryan Pape
Lead Acoustician
bpape is offline
post #358 of 855 Old 08-08-14, 05:05 PM Thread Starter
ellisr63's Avatar
Ron
If I use solid plywood won't that create a triple effect? Maybe I should just use 1/2" plywood and wrap the material around it?
Ron
My Home Theater
ellisr63 is offline
post #359 of 855 Old 08-09-14, 10:32 AM
bpape's Avatar
Bryan Pape
As long as there isn't a gap between the drywall and the plywood it's not at all a problem. The problem exists when you have more than one sealed air gap which you won't have.
Bryan Pape
Lead Acoustician
bpape is offline
post #360 of 855 Old 08-09-14, 01:04 PM Thread Starter
ellisr63's Avatar
Ron
How do I determine where to place the sound panels on the wall in regards to height? The panels are 2' x 4'... Would 2' off the floor, and leaving a gap under the soffit be ok? Our soffit is 1' from the ceiling but it stops about 6' from the screen... Which means the panels then have to go up 1' higher. I am thinking cosmetically it would be better to keep the distance from the floor the same (until it meets up with the 2nd row seating) the same, but I don't want to mess up the sound either.
Ron
My Home Theater
ellisr63 is offline
home , retirement , theater
