Ellis Family Retirement HT: Go big or go home - Page 40 - Home Theater Forum and Systems - HomeTheaterShack.com
 43Likes
post #391 of 856 Old 09-11-14, 06:56 AM
Owen Bartley's Avatar
OJ
The only thing that comes to mind right away for me are zip ties for something semipermanent, or velcro tape for easy removal. I'm not sure if those units get warm, which might affect the longevity of the tape.
- OJ -
Owen Bartley is offline
post #392 of 856 Old 09-15-14, 02:05 PM Thread Starter
ellisr63's Avatar
Ron
Re: Ellis Family Retirement HT: Go big or go home
I think I have a way that should look nice and work... I purchased some 1x1 Oaks strips, and some 1/4" x 1" Oak, glued them together, and now I am cutting them into blocks that will be used to separate the pieces. I will then use a 1/4" x 1" strip that will be screwed down on top of the blocks (holding the pieces in place). I will post some pics when I get this completed. Hopefully this new way will work.
Ron
My Home Theater
ellisr63 is online now
post #393 of 856 Old 09-15-14, 08:57 PM Thread Starter
ellisr63's Avatar
Ron
Here is my solution (mock up)... I still need to make a new back board that is longer and wider (2'x8') which should allow me to add my 2 TV tuners as well as my other i3NUC to the setup. What do you think?
Ron
My Home Theater
post #394 of 856 Old 09-15-14, 09:12 PM
duder1982's Avatar
I think it looks great, good job.
duder1982 is offline
post #395 of 856 Old 09-15-14, 09:58 PM Thread Starter
ellisr63's Avatar
Ron
duder1982 wrote: View Post
Thanks, I made it out of 1"x1" Oak with a layer of 1/4" Oak glued to it and then cut in 3" chunks. For the top I will be cutting it into sections so that each piece can be removed without taking off one large strip... Or at least that is the plan. Hopefully I will be able to get the next part done tomorrow.
Ron
My Home Theater
post #396 of 856 Old 09-16-14, 08:12 AM
OJ
Looks like someone needs some custom cables!
It looks good, really clean. Is there enough room for the components to get some air?
E: (just noticed I already mentioned heat above... sorry, it's still early).
- OJ -
post #397 of 856 Old 09-16-14, 10:36 AM Thread Starter
ellisr63's Avatar
Ron
Owen Bartley wrote: View Post
The only devices that i think will get warm are the 2 i3NUCs... I have been thinking of mounting all the pieces to a piece of pegboard and then standing the pegboard off from the wall with a 2x4. If I do it that way the only area that won't be getting air is the 1" area on each side where the wood touches the component. The i3NUCs have their cooling on the bottom so I def need ventilation under them. The other option would be to make the whole back platform solid and use a hole saw to cut a vent hole for the i3NUCs, and install a small fan under it (the board would still be raised off the wall by at least a 2x4 distance). What do you think of that?
Ron
My Home Theater
post #398 of 856 Old 09-16-14, 03:06 PM
OJ
I think I'd definitely cut a hole under the components once your layout is finalized. Can't hurt, you won't be able to see it, and anything that has the potential to get warm will have a little extra breathing room.
- OJ -
post #399 of 856 Old 09-17-14, 01:42 PM Thread Starter
ellisr63's Avatar
Ron
I just punched in my room dimensions in and got this...
What does this tell me I need to do in the room? Do I need to focus on the 22, 31, and 67 Hz to absorb first, and then work on the other frequencies?
Ron
My Home Theater
post #400 of 856 Old 09-17-14, 01:59 PM
HTS Senior Moderator
bpape's Avatar
Bryan Pape
22 and 31 you're not going to touch - just being honest. All that is telling you is that those are where your modes are and where they'll be in the room. It tells you nothing about the time domain, getting reflections dealt with, getting decay time down to a reasonable level across the spectrum, etc.
It's really just a way that If you run into a problem, look at these and see if the problem matches up with one of these so you have a better idea of how to address it either via movement or treatment - or if neither of those can work and it's a peak, equalize it.
Bryan Pape
Lead Acoustician
bpape is offline
home , retirement , theater
