Ellis Family Retirement HT: Go big or go home - Page 43 - Home Theater Forum and Systems - HomeTheaterShack.com
 43Likes
post #421 of 855 Old 10-08-14, 09:59 AM Thread Starter
ellisr63's Avatar
Ron
Re: Ellis Family Retirement HT: Go big or go home
Yeah, I am hoping my Contractor completes his job this weekend and finishes the hallway, and HVAC part so I can continue with the everything else.
Ron
My Home Theater
ellisr63 is offline
post #422 of 855 Old 10-08-14, 10:12 AM
HTS Senior Moderator
bpape's Avatar
Bryan Pape
Sorry - been swamped. Try bumping it up just a little bit and see if the response follows. If not, then they're likely modal nulls and you won't fix them just with a level adjustment. You'll need to address one of the 2 cancelling waves via room treatment. Or, play with the sub position and see if you can gain a little there, or both.
Bryan Pape
Lead Acoustician
bpape is offline
post #423 of 855 Old 10-08-14, 10:21 AM Thread Starter
ellisr63's Avatar
Ron
bpape wrote: View Post
Thanks Bryan
Ron
My Home Theater
ellisr63 is offline
post #424 of 855 Old 10-14-14, 11:16 AM Thread Starter
ellisr63's Avatar
Ron
Question Re: Ellis Family Retirement HT: Go big or go home
If I move my 4" absorber panels to the ceiling and make new 4" panels for the walls...
What would happen if I put pegboard on the front side of the panels and then wrapped them with GOM? Would that allow me to use more panels (to help with the bass traps) without hitting the highs too much? My thinking is that the pegboard would allow some high frequencies to be absorbed and reflect most of them... While at the same time absorbing some of the bass.
Ron
My Home Theater
ellisr63 is offline
post #425 of 855 Old 10-14-14, 11:27 AM
bpape's Avatar
Bryan Pape
If you want to not hit the highs, use a membrane of some sort. Mass will determine the cutoff - FSK, Pond Liner, or even MLV will cut off progressively lower.
Bryan Pape
Lead Acoustician
bpape is offline
post #426 of 855 Old 10-14-14, 11:40 AM Thread Starter
ellisr63's Avatar
Ron
I take it that I should not put any membrane on first reflection points, correct? If I use a membrane (not on first reflection points) can I do all the walls with 4" thick Roxul, or will that still be too much? Is this a good idea?
Ron
My Home Theater
ellisr63 is offline
post #427 of 855 Old 10-14-14, 12:49 PM
bpape's Avatar
Bryan Pape
Reflection points need to be full range. I would not cover all the wall surface with anything. Too much. You need to know what your target decay time curve should be, address the things you know you need to do (front wall, reflections, and broadband bass control), then see what you have left and balance it out accordingly.
Bryan Pape
Lead Acoustician
bpape is offline
post #428 of 855 Old 10-14-14, 12:55 PM Thread Starter
ellisr63's Avatar
Ron
So basically... I should make my front, and rear wall panels, and first reflections for ceiling, and walls, and then measure?
Ron
My Home Theater
ellisr63 is offline
post #429 of 855 Old 10-14-14, 01:37 PM
bpape's Avatar
Bryan Pape
And corners.
Bryan Pape
Lead Acoustician
bpape is offline
post #430 of 855 Old 10-14-14, 01:44 PM Thread Starter
ellisr63's Avatar
Ron
And corners.
I will be using 6" of Roxul 60 on the whole rear wall... I was thinking of angling the panels in the rear corners with the same panels that are on the rear wall... Is that enough? The front wall will have 3" of Roxul R60 wall to wall... Do I need to build out some more for the corners too?
Ron
My Home Theater
ellisr63 is offline
home , retirement , theater
