Ellis Family Retirement HT: Go big or go home - Page 48 - Home Theater Forum and Systems - HomeTheaterShack.com
 43Likes
post #471 of 856 Old 11-26-14, 03:18 PM Thread Starter
ellisr63's Avatar
Ron
Re: Ellis Family Retirement HT: Go big or go home
bpape wrote: View Post
Yes. Just fine the reflections for the center 2 channel seat and treat those with diffusion. Get something that's going to get down reasonably low. A 6" thick diffuser should get down to around 300Hz.
Sounds good... I have some old plans for the RPG QRD type diffusers... I am assuming that would be better than the RPG SkyLine type?
Ron
My Home Theater
ellisr63 is offline
post #472 of 856 Old 11-26-14, 03:28 PM
HTS Senior Moderator
bpape's Avatar
Bryan Pape
Skylines are a QRD type design. They're just not deep enough for what we want to do. Plan on at least 6" deep.
Bryan Pape
Lead Acoustician
bpape is offline
post #473 of 856 Old 11-26-14, 03:59 PM
Quenten
It would be great if you could post those plans or do a build thread. Haven't seen much on diffusor builds & I'm more than likey going to need them (or a reasonable faximily) in my room as well.
Tonto is offline
post #474 of 856 Old 11-26-14, 07:59 PM
HTS Moderator
doug
2nd this - I have been looking at building some too. They look very tedious to make
dougc is offline
post #475 of 856 Old 11-26-14, 08:24 PM Thread Starter
ellisr63's Avatar
Ron
Years ago I made two of them 4' x 4', and I really liked them. This time i will most likely do them in 2' x 2', and then cover them with black Acoustically Transparent GOM.
These are the ones I purchased... http://www.acousticfields.com/produc...atic-diffusor/ (I am not sure about posting ones that were purchased... Plus they are pretty inexpensive).
Here are some free ones... http://arqen.com/sound-diffusers/
Here is a calculator... http://arqen.com/sound-diffusers/
Ron
My Home Theater
ellisr63 is offline
post #476 of 856 Old 11-27-14, 08:43 AM
bpape's Avatar
Bryan Pape
Be very careful. All of those designs are symmetric patterns. Repeating symmetric patterns next to each other can cause comb filtering. If your requirements are to have 2 diffusers next to each other then they need to be asymmetric and the pair needs to be hung mirror imaged to each other.
The plans from Argen are only 50-60mm deep so not much good below about 7-800hz.
Try QRDude to design your own
http://www.hometheatershack.com/foru...alculator.html
Pay attention to the 'rules' it checks against.
Bryan Pape
Lead Acoustician
bpape is offline
post #477 of 856 Old 11-27-14, 10:48 AM Thread Starter
ellisr63's Avatar
Ron
Thanks Bryan, I will look at QRDude and design my own.
Ron
My Home Theater
ellisr63 is offline
post #478 of 856 Old 11-27-14, 11:07 AM Thread Starter
ellisr63's Avatar
Ron
Question Re: Ellis Family Retirement HT: Go big or go home
It looks like , if I can cover them with AT GOM, I can go a max of 10" deep per side (using the Diffusers as a masking panel too). Since I am as large as I can possible go already due to no more room to move the projector back... The only way I could go larger would be to move my Rack (which would be a major rework). Should I go the max depth I can? 10" will give me down to 226Hz, where as 8" will give me 283Hz.
Ron
My Home Theater
ellisr63 is offline
post #479 of 856 Old 11-27-14, 11:14 AM
bpape's Avatar
Bryan Pape
Masking panels on the front wall? You want absorption there. The diffusion was for side wall reflections.
Bryan Pape
Lead Acoustician
bpape is offline
post #480 of 856 Old 11-27-14, 02:33 PM Thread Starter
ellisr63's Avatar
Ron
The panels will be for first reflection mounted on the side walls but the thickness of them will be doing a double duty as masking the screen or in other wards making a side boarder for the front screen.
Like this...
Ellis Family Retirement HT: Go big or go home-screen-drawing.png
Ron
My Home Theater
ellisr63 is offline
home , retirement , theater
