Ellis Family Retirement HT: Go big or go home - Page 6 - Home Theater Forum and Systems - HomeTheaterShack.com
 17Likes
post #51 of 793 Old 02-02-14, 10:22 AM Thread Starter
ellisr63's Avatar
Ron
Re: My retirement Home Theater
bpape wrote: View Post
The reason some folks use MDF on the layer closest to the studs is to provide a mounting surface anywhere in the room. Drywall on the facing layer for the smoothest, best looking, easiest to paint layer showing.
Would MDF work better than drywall for acoustics?
Ron
My Home Theater
Yamaha CX-A5100, (3) JBL 2360A/EV DHA-1s, (3) 1/4 Pie bass bins, (2 pr) JBL 8340As, (2 pr) JBL 8320s, PS3, XBox One, (2) Intel NUCs, Redmere HDMI cables, Monster Signature HTPS7000, (2) Furman Power Conditioners, (2) DTS-10 subs, Panasonic AE8000, SeymourAV 180 (195" diag) scope screen, Darbee Darcet, Panamorph UH-480 lens, (2) Crest Audio 2208, Yamaha XM-4080 & P7000s, (2) MiniDSP DDRC-88M, Oppo UDP-203
ellisr63 is offline
post #52 of 793 Old 02-02-14, 10:26 AM
HTS Senior Moderator
bpape's Avatar
Bryan Pape
It's just for isolation, not to do with in-room acoustics. All a matter of mass in terms of isolation.
Bryan Pape
Lead Acoustician
bpape is offline
post #53 of 793 Old 02-02-14, 11:38 AM Thread Starter
ellisr63's Avatar
Ron
So would MDF be better than drywall in terms of isolation and mass?
Ron
My Home Theater
ellisr63 is offline
post #54 of 793 Old 02-02-14, 12:16 PM
bpape's Avatar
Bryan Pape
Realistically about the same though MDF will be more expensive and not flex as much as drywall. Trading motion eating pressure vs rigidity. Drywall will be more predictable.
Bryan Pape
Lead Acoustician
bpape is offline
post #55 of 793 Old 02-02-14, 02:39 PM Thread Starter
ellisr63's Avatar
Ron
OSB is not as good as drywall either, correct?
Ron
My Home Theater
ellisr63 is offline
post #56 of 793 Old 02-02-14, 03:08 PM
bpape's Avatar
Bryan Pape
Nope. Not as much mass.
Bryan Pape
Lead Acoustician
bpape is offline
post #57 of 793 Old 02-02-14, 03:12 PM Thread Starter
ellisr63's Avatar
Ron
So if a person is going to hang acoustic panels they should do one layer of OSB and follow up with one or two layers of drywall, correct? If you forgo the OSB would screw in anchors work for hanging acoustic panels or does that defeat the purpose of using clips?
Ron
My Home Theater
ellisr63 is offline
post #58 of 793 Old 02-02-14, 03:24 PM
bpape's Avatar
Bryan Pape
Panels can hang just on the drywall with the right anchor. OOKS hooks work great. No need to find a stud even. VERY small nail hole - much smaller than the auger type drywall anchors.
OSB/MDF are used for things like when you don't know where the surrounds would be, if you need to hang shelves, etc. But if you know in advance, you can also just use cross braces between studs in the proper locations and use all drywall.
Bryan Pape
Lead Acoustician
bpape is offline
post #59 of 793 Old 02-02-14, 03:36 PM Thread Starter
ellisr63's Avatar
Ron
Gotcha, thanks.
Ron
My Home Theater
ellisr63 is offline
post #60 of 793 Old 02-09-14, 04:27 PM Thread Starter
ellisr63's Avatar
Ron
Well we should have the garage ready to start construction on in a week or two...
This is what the plan is so far.
1:Cut out the door opening and install a solid core door from the garage to the house.
2:Build the hallway wall (not sure if this should be done before or after ceiling and raised floor)
3: Open up the ceiling and walls to re do the sound insulation
The next step I am not sure of... Should the floor or ceiling be built next?
For the ceiling we will be doing the 1/4" foam board, GG, drywall, insulation,GG all of this between the beams and then... Drywall, GG, Drywall
For the floor we are planning on moisture barrier 2x4 with 3/4" OSB (insulation in the sub floor if it will fit).
I figure the drywall on the walls will be after we have demo'd the speakers in the room.
How does this sound? Is this the correct order to do this? Suggestions? Do we do the electrical wiring before we do the 1/4" foam in between the ceiling joists or after? I am thinking it would go in the fiberglass insulation layer but I am not sure.
Is anyone familiar with these Genie Clips? Are they any good?
Ron
My Home Theater
ellisr63 is offline
home , retirement , theater
