In about a month I plan on breaking ground on starting to convert our 2 car garage to a dedicated home theater. The garage is already dry walled and we will be ripping out the drywall on the walls and ceiling to see what we have to work with. The garage is 23' 4" long, 19' wide with a 9' ceiling. We have a door on the backside of the garage that leads out to our pond, a water heater, and furnace are in the wall right next to the door, and these need to be taken into consideration for the dimensions of the theater.
We will be extending the front of the garage out 5' to enclose our front channel speakers (3 La Scalas (heavily modified) , 2 Heresy HIPs and 1 of 2 Danley DTS-10 subs).. The goal is to hit 115db @ 10hz with a low power amp. I am trying to cut down our electricity bill as much as possible so a friend of mine is building me a 10 channel "D" class chip amp that will put out no more than 30wpc... Since all my speakers are 98 db or greater efficiency I figure this should be more than enough power to listen at reference levels.
The walls will be built as a double 2x4 wall with fiberglass insulation, OSB, and 2-3 layers of sheet rock with green glue. The ceiling will be 2 layers of sheet rock and maybe OSB if the ceiling can support the added weight of the OSB. Making the room as quiet as possible is a must as it is right below our Master Bedroom and I like to watch movies late at night.
We will be running 12 gauge Monoprice cable in conduit for all 9 channels. We are using Monoprice Redmere cables for all HDMI. The equipment rack location will be on the same wall as the Heater and water heater.
Are the room dimensions good for a HT or could they be reduced in some areas to get a better setup?
I will try and get some drawings up so this setup will make more sense. Any suggestions are welcome as I want to do this right the first time.
Parts list:
USB electrical outlets for power recliners
5/8" drywall (2 layers)
Green Glue 5 gallon buckets
Specs:
walls 24" on center
Finished pics...
Looking from the HT to the pond entrance.
Looking from the HT entrance to the Skimmer.
Entrance to the HT.
Here you can see the door.
New seats. (have been moved to the front row)
We now have our HT door sign temp mounted (it will be flush mounted soon). I also have a Panamorph UH-480 lense arriving next week. I am hoping I can get more brightness, and not have to worry about changing aspect ratios in some movies.
Daytime...
Night time (color is different as it is set to randomly change the LED colors)...
Parts list:
Specs:
walls 24" on center
Finished pics...
Entrance to the HT.
Daytime...
