Blacking out windows? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Discuss Blacking out windows? in the Home Theater Installation and Systems forum; Blacking out windows? I am looking for some type of shade to black out the two windows in my theater room. Can someone ...
Old 11-10-07, 09:58 PM   #1 (Link)
Alias: Blake
Loc: Murfreesboro, TN
Atama's Avatar
User: #12201
Since: Oct 2007
Atama is offline
I am looking for some type of shade to black out the two windows in my theater room. Can someone recommend some type of shade that they have used that BLACKS OUT a window?
Old 11-11-07, 06:28 AM   #2 (Link)
Alias: mike
Loc: Olney, Illinois
mikeb's Avatar
User: #3292
Since: Oct 2006
mikeb is offline
Re: Blacking out windows?
Atama wrote: View Post
Hi Blake, will this be permanant or will you be opening and closing them. I wanted my room totally black so I went to Wal Mart and purchased some black material back in the section guys don't like to hang out much, covered the windows and then coverd with curtains that have a theater feel to them. I do not know of any window covering that will give a total blackout and still be useable.
Old 11-11-07, 12:55 PM   #3 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is offline
There is also "blackout cloth", used to line the inside of drapes, it's white, and blocks 100% of light. Most sewing supply shops sell it.
Old 11-11-07, 02:30 PM   #4 (Link)
Alias: Blake
Atama's Avatar
User: #12201
Since: Oct 2007
Atama is offline
I was hoping for something that could be opened during the day, because my room pulls doulbe duty as my home office (i know, distractions, distractions). I saw somehting on one of those HGTV shows once that was similar to a pull down shade. I realize that TOTAL balckout is probably not gonna happen with this type set up, but want something that is as effective as possible.
Old 11-11-07, 03:34 PM   #5 (Link)
Bronze Supporter
Alias: FJ
Loc: Marysville, WA
User: #11951
Since: Sep 2007
Scuba Diver is offline
It really depends on what works for you. If money is no object just buy some nice Hunter Douglas Blackout blinds and hang a drape in front of it. It will make the room very dark.
If DYI is what you are looking for then many options are available.
Would plugs work for you? I have seen several people use foam board cut to fit the inner diameter of the window opening. Works to dampen sound and block light.
I personally have constructed swinging doors and sliding doors for windows.
I have also seen someone use a slightly modified soundproofing blanket as a drape. It worked well too.
Just remember light is like water or sound if there is crack, gap or opening of any kind it will find its way in. If you want a pitch black room a door or plug can be designed to completely block out light.
Blackout cloth can be purchased at the fabric store and will also work very well to darken the room. With a little effort you could incorporate snaps or Velcro that could help seal out light to make the room very dark while still allow fairly easy removal
Old 11-11-07, 04:20 PM   #6 (Link)
Shack Podcaster
Alias: Marshall
Loc: Hudson Valley, NY 12569
eugovector's Avatar
User: #2411
Since: Sep 2006
eugovector is online now
I use blackout drapes from Target (out of stock, try bed, bath, and beyond). These block out about 80% in bright daylight. Hand a double rod and put these on the outside with blackout cloth on the inside, and you'll be set.
Old 11-11-07, 04:56 PM   #7 (Link)
Shack Helper
Alias: Prof.
Loc: South of Adelaide
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is offline
As has already been mentioned, you can get black blockout blinds from most Decorating centres..BUT..regardless of how good the blind is, you will still have light leaks at the edges and the top..
I'm in the same situation..I have a blockout blind on the back wall which works well, but there are light leaks at the sides and the top, so I'm going to make a pelmet to cover the roller part of the blind and side coverings down the length of the blind, and paint the whole thing matte black..
I tried it with just holding a side covering in place, and it blocked the light on that side..
I hope that is of some help..
Old 11-12-07, 07:05 PM   #8 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
I have one window in my Ht ... I made a pair of sliding doors, they're always closed, but if I need light I just open them.
What about tinting film??? ... maybe you can use the darkest you can find (for cars I think is called limo) and then add courtains inside ... ... that will also help with heat and cold.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
Similar Threads
Windows XP Tips & Tricks jvc Computers | Games | HTPC | Digital Devices 6 07-29-07 07:39 AM
Does Windows XP updates mess with REW? rcarlton REW Forum 3 07-01-07 05:59 PM
Error Message on Windows Vista eliaspm15 REW Forum 1 11-16-06 06:58 AM
IBM PC Meets Windows 1.0 Wayde Home Theater, Audio and Video News 0 09-27-06 01:50 PM
Windows Vista includes HD audio enhancement HDBeat Home Theater, Audio and Video News 0 09-08-06 03:06 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
