Designing a home theater from scratch - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Discuss Designing a home theater from scratch in the Home Theater Installation and Systems forum; Designing a home theater from scratch Hi, I'm new to the forum. I'm building a new home theater from 'scratch'. Actually, I'm building a new home, ...
Old 11-17-07, 02:57 PM   #1 (Link)
New Member
Alias: Neal
Loc: Atlanta
User: #13487
Since: Nov 2007
Neal_3 is offline
Hi, I'm new to the forum. I'm building a new home theater from 'scratch'. Actually, I'm building a new home, so I have a good bit of flexibility (as far as room design goes).
I'll read the suggested links in the '101' post above, but I'd like some advice...
What I need help to determine is basic room design (size, building materials, etc.) for the architect. The Media room must, unfortunately, be in the finished basement. The costs need to be kept within reason (high quality components, not top-of-the-line).
Here's the basic specs:
  • 10' diagonal screen (approx)
  • 1080p projector - probably 3LCD, to avoid the 'rainbow' artifact
  • seating for 8 comfortably, 12 in a pinch; 2 rows are currently planned
And here are my most pressing issues:
  1. What are reasonable room dimensions?
  2. How high (within reason) should the ceiling be to allow for reasonable acoustics?
  3. How feasible would it be to have a 2-level floor, so that seats in back still have a good view?
  4. Are there special construction materials I should consider / avoid?
  5. Other than carpeting, what would be good flooring materials?
  6. Would a separate closet area for the projector and/or other equipment be a good idea - If so, where would be the best placement (rear, side, etc)?
  7. If you had COMPLETE control what would you suggest? OR are there DECENT books available? (I haven't found any yet?)
Any suggestions would be GREATLY appreciated. Thanks in advance!
Oh, and here's a pic of the site of my new home theater; you can tell why my wife and I are so excited these days...
Old 11-17-07, 03:46 PM   #2 (Link)
drf
Alias: drf
Loc: Somewhere else.
drf's Avatar
User: #3282
Since: Oct 2006
drf is offline
Re: Designing a home theater from scratch
Firstly, how could you doze that beutifull site to build?
have you had a read through the design and construction threads?
Lots of great info there including help on sound isolation and treatment.
Good luck.
Dr F
"Until mankind is peaceful enough not to have violence on the news, there's no point in taking it out of shows that need it for entertainment value." - Clueless
The imperative is to make a subjective study an objective fact.
Old 11-17-07, 06:17 PM   #3 (Link)
Alias: Jeff
Loc: Greenville, SC
Captain Crunch's Avatar
User: #7934
Since: Apr 2007
Captain Crunch is offline
Now maybe it's just me but I think all that open space is really going to hurt you base response. Maybe you could try the sub next to the big oak on the left!
Old 11-18-07, 12:23 AM   #4 (Link)
Loc: Lower Alabama
Sonnie is offline
Hi Neal and welcome to the Shack!
I can feel the excitement myself and wish I was in your shoes.
There are guys here a whole lot more knowledgeable about this stuff than myself, but I'll throw some things at you just so you'll have some options.
Neal_3 wrote: View Post
Probably the max you'd want to do is 10'... and if you want to save you can check out our professionals over in our DIY Screen forum. No doubt you can fix up a screen that will rival the best.
If I had the money I would be all over the new Panny 2000 2nd generation 1080p projector. Check out the reviews at Projector Central. It is the real deal. I got to figure out a way to afford it myself.
I'd stick with 2 rows of 4... a good number. Not sure what you got planned for seating, but Roman with Ultimate Home Entertainment is one of our sponsors. Check out the Home Theater Seating forum here at the Shack and see the current special he's got going. Call him up and he'll deal with you on some seating.
What's your max you can do here? For two rows of 4 seats and a riser for the second row, I'd probably shoot for something like 14' W x 23' (or 26') D x 10' H, although the 10' may be hard to do in a basement.... if you plan it, it will only cost about 3 more rows of block... and it would be well worth it. This will also give you plenty of room for acoustic treatment... and again we have a great sponsor for treatment with GIK Acoustics.
Very feasible and easy to do. Definitely plan the riser in the rear.
I'll leave this one totally to some others.
I would stick with carpet with a good thick padding for acoustics.
You can mount the projector center of the screen about 10-12' back on the ceiling. Most all of the 1080p pj's are going to be super quiet... especially the Panny. Go ahead and run some 3" PVC pipe in the ceiling when you build along with installing a receptacle where the pj will be mounted.
We expect pictures every step of the way...
Old 11-19-07, 03:05 PM   #5 (Link)
Alias: Zip
Loc: Canada
MatrixDweller's Avatar
User: #10408
Since: Jul 2007
MatrixDweller is offline
Here's some ideas about room size:
Since you haven't built yet and will be pouring a foundation and slab you could make the front of the room 10 or 12 feet high and the rear, which would hold the second row of seats, 8 to 10 feet high. You could incorporate steps (one or two) on either side of the room to get from level to level.
10' diagonal would be almost 9' wide and 5' tall without the frame. So your room should be no less than 12' wide to give 1.5' of space on either side of the screen. I'd recommend a little more space though unless you plan on putting the speakers behind the screen. There are also ideal room dimensions for room acoustics. a 23 x 16 x 10 (l x w x h) fits. Download ModeCalc from www.realtraps.com to get a better understanding of what modes your room will have.
The optimal viewing distance for a 120" screen is somewhere between 13 1/2 and 19 feet according to the THX standard. So two rows of seats at 14' and 18' would fit nicely. Here's a calculator for optimal viewing distance: http://www.myhometheater.homestead.c...alculator.html
BTW: The Panasonic Sonnie mentioned I think is what everyone is drooling over, including me.
Old 11-19-07, 08:40 PM   #6 (Link)
New Member
Alias: Neal
Loc: Atlanta
User: #13487
Since: Nov 2007
Neal_3 is offline
“Firstly, how could you doze that beutifull site to build?”
Yeah, I know. :-( However: It’s a huge lot, we’re only cutting the minimum number of trees, and we saved it from the lumberjacks who wanted to clear-cut it (really!), so I don’t feel so bad about it. The land cost twice what we budgeted (but is DEFINITELY* worth it), so we’re going to need to trim costs carefully elsewhere.
Secondly, THANKS for all the helpful advice. The calculators are especially useful at this stage. I currently own a Panasonic TV and will certainly consider the 2000.
“What's your max you can do here?”
As far as max size, I’m not sure; I’m meeting w/ the architect tomorrow and will have a much better idea by then. I had been thinking of something along the lines of 23x17x9 or so. The main issue is ceiling height, due to the in-the-basement requirement. As it is, the room will need to have a “sunken” floor, since the rest of the basement will likely have an 8’ ceiling due to cost considerations. My goal is a good-quality “screening room” atmosphere, but without the stadium seating.
“I would stick with carpet…”
Unfortunately, due to our large number of pets, carpeting is a bad idea. Any other suggestions?
“We expect pictures every step of the way...”
Actually, I WAS planning to do that, but it’s likely to be posted over at Bjorn3D.com, where I’m a staff writer. (Don’t worry; I’ll post links.) Keep in mind that the groundbreaking is still at least a couple of months away. (First we need to finalize the blueprints and install a LONG driveway across the creek…)
*There’s even a waterfall (note that we're in the middle of a drought situation)…
Old 11-20-07, 12:03 AM   #7 (Link)
Loc: Lower Alabama
Sonnie is offline
Who needs a home theater with that view? Nice!
If you don't use carpet then you will most likely need a rug or two and lots of acoustic treatment in the room.
Old 11-20-07, 01:02 PM   #8 (Link)
Alias: Jeff
Loc: Greenville, SC
User: #7934
Since: Apr 2007
Sonnie wrote: View Post
Everyone ignore Sonnie, he must be having an off day.
I'm all for a nice view Sonnie..
But I believe you just committed a sin.
I'm pretty sure in the (10 commandments of Theater)
You just broke commandment #1
Thou ll shalt put nothing before thy THEATER!!
Old 11-20-07, 03:51 PM   #9 (Link)
Alias: Zip
Loc: Canada
User: #10408
Since: Jul 2007
Instead of wall to wall carpet you could go with carpet tiles. If you get a few extras they can be replaced easily if Fido decides to do a #2 in your #1 room. High traffic low pile carpet that has Scotch Gard or similar sprayed on it is pretty resistant to pet stains BTW.
The reason carpet is a better choice is that hard surfaces will reflect sound better which impacts the room acoustics. If you went with hardwood, laminate or tile you would want to put some rugs down to reduce the floor's reflectivity.
Cork is a little more flexible and would do a better job than other flooring in controlling reflections. It might be worth investigating.
You would also need to build a sub floor if going with hardwood and although you can get away with not having one with laminates it is normally not recommended. With tile you need a sub floor plus another 1/4 inch of rhino board or Kerdi mat or other material. The subfloor will reduce your ceiling height by a couple inches.
You could put carpet and underpad right on the slab as long as you have a vapor barrier under it. That would reduce your cost a bit. I still prefer a sub floor even with carpet because it makes the floor more comfortable (softer) and warmer. If your slab is not insulated underneath you can insulate with styrofoam between the slab and the subfloor. Better yet use Rockboard or OC 703 for better sound absorption. The money you spend on the insulation will pay for itself in lower heating costs.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
Similar Threads
Designing a sub... software, etc. Boris Yeltsin DIY Subwoofers 4 03-01-08 02:19 PM
My little Home Theater JRace Home Theater Equipment 2 06-06-07 04:42 PM
Need Help Designing Home Theatre max1565 Home Theater Design and Construction 5 04-26-07 12:10 PM
:scratch: Cannot seem to get started? nater REW Forum 1 03-21-07 10:21 PM
Home Theater vs Movie Theater Roger Home Theater, Audio and Video News 0 05-09-06 07:45 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
