Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Help in Design of Difficult New Home Theatre New Home Construction
Discuss Help in Design of Difficult New Home Theatre New Home Construction in the Home Theater Installation and Systems forum; Help in Design of Difficult New Home Theatre New Home Construction If you have only one row - or - you want to optimize for the front row at the expense ...
Views: 2113 - Replies: 65
Old 09-15-08, 07:24 AM   #51
Design and Acoustics Moderator
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
Re: Help in Design of Difficult New Home Theatre New Home Construction
If you have only one row - or - you want to optimize for the front row at the expense of the 2nd, then dipoles directly beside the front row are correct. If you want to compromise slightly to improve the effect for the 2nd row, then placing the sides between the rows (still 6-6.5' high) is an option.
Rears, personal preference. I prefer monopoles in a 7.1 setup with dipole sides. In either case though, they should also be around the same height.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 09-16-08, 01:35 AM   #52
Alias: Oil Country
Loc: Edmonton AB Canada
User: #13730
Since: Nov 2007
  Conrad is offline
Thanks Guys for the info, just to recap. First I am only going to have one curved row of four seats. I figure to my best guest my head will be approx. 11 feet from screen and 3.5 feet from back wall.
So I should have wires come out at side walls 11 feet back at 6 to 6.5 feet above floor? Is that correct?
I spoke to Drywall guy and he said he can fix anything I cut. Of course it will cost $$$ because I did not think to pull those wires. But at least I put wires there whew!!!
Once I have wires pulled I will post new photos of all wire placements. And will post all exciting screen info I have gathered so far soon.
Thanks
Again in Advance
Conrad
Old 09-16-08, 01:38 AM   #53
Alias: Oil Country
User: #13730
Since: Nov 2007
  Conrad is offline
Oh sorry Prof I do have front firing speakers for rear as of now I may switch to Dipole if I need to. Do you think this room because of its shape would benefit from Dipole speakers.?
Cheers
Conrad
Old 09-16-08, 08:39 PM   #54
Shack Moderator
Alias: Prof.
Prof.'s Avatar
Loc: South of Adelaide
User: #3204
Since: Oct 2006
  Prof. is online now
Conrad wrote: View Post
If you're 11' back when sitting in the centre of the curved seating..then yes..
I would just have dipoles on the side walls and monopoles on the back wall..as Bryan suggested..should be fine in that room..
Prof..
Home Theatre...the never ending story!
Old 10-20-08, 01:21 AM   #55
Alias: Oil Country
User: #13730
Since: Nov 2007
  Conrad is offline
I took everyones advice here and it is done I now have another option for a pair of speakers. You can say now I can have wired in my room 9 speakers and 2 subs do they even process that yet?
I will send updated photos when I get a chance.
Cheers
Conrad
Old 10-20-08, 01:30 AM   #56
Alias: Oil Country
User: #13730
Since: Nov 2007
  Conrad is offline
Just to update on room design now I am in the middle of now selecting my home theatre projector and I am definitely going to go with Panasonic PT-AE3000. As being able to have a 2.40 screen without all the extra gear is just great. It is a dream come true at the right time I was ready to drop maybe 8 to 12 grand for Panamorph set up now should be able to save thousands of dollars!!!!!!! I have been doing a lot of reading of the pros and cons of this projector but the price is right and I what I am hearing your are not giving much up on image quality!!!
That being said my projected screen size is to be 45 inches by 108 inches with a 117 inch diagonal. I figure top of screen material will be at 83 inches from floor. My room is 15 ft 2 inches deep and 14.5 feet wide with 9 foot ceiling as seen in earlier posts here. I figure seating position will be at 11.5 to 12 feet back from screen. Walls and ceiling will now be medium brown in color with Wine color wall in back of room. And room is 100% light controlled complete darkness if needed.
I want to build a shelf for projector to sit on at back of room coming from back wall. Instead of ceiling mount I have my own personal carpenter and he can build this shelf very easily and it wont distract from LED Rope lighting like ceiling mounted projector would.
Question 1. At what height should I build shelf for Pany 3000 to sit on and how far from back wall should I allow for air space? And should projector be at front of shelf? And should shelf just be big enough to hold projector?
Question 2. Any thoughts or comments on screen size? I spoke to Stewart and Da-Lite and they both came up with this size but when was at local Audio/Video store they thought screen was to big and said Stewart and Da-Lite reps just use formulas and don't really understand what to use? And I should go for a 40 inch CIH screen. This seems kind of small any thoughts on this?
Question 3. And lastly any thoughts on what Stewart or Da-Lite screen to go with my room.
Question 4. Now I am going with Anamorphic screen at 117 inches where should I put my front speakers I think I do not have enough room depth for stage and hidden speakers. Will the sound field be to far away from a screen this wide? Has anyone had a similar size screen width towers at ends of screens? Did this sound good still?
Thanks In Advance
Conrad
Old 10-20-08, 02:24 PM   #57
Alias: Zip
MatrixDweller's Avatar
Loc: Canada
User: #10408
Since: Jul 2007
  MatrixDweller is offline
The 3000 has lens shift so you could mount the shelf at practically any height. The only thing you need to consider is obstructions (ie: people standing up, chairs int he way. Ideally you want the PJ as close to the screen as possible to give you your desired picture size. That helps with brightness and people standing up and blocking the image.
For the shelf you'll also want to make sure you have adequate airflow by the intake and exhaust. My Epson 550 has it's intake on the bottom so I cut some breathing holes in the bottom of the shelf. As long as the intake isn't obstructed and there are no obstructions to the left and right of the projector then minimal space should be needed. Make sure the exhaust isn't contaminating the intake (which it shouldn't unless blocked).
As for shelf size and projector placement on the shelf. You could use any size really. You would not want the projector lens to be back too far if the shelf was deep as it might block the light, but other than that shouldn't matter. Projectors can run while sitting on desks so airflow shouldn't be an issue.
Screen width could be 2/3 as wide as your seating position is from the screen. So if you sit 12 feet back then approximately an 8 foot (96") wide (not diagonal) screen would work. Check out this viewing distance calculator: http://myhometheater.homestead.com/v...alculator.html. At 40" height and 2.35:1 ratio the width would be 94". If you like to sit closer to the front of the movie theater then bigger might suit you.
You will also want to consult the projector's projection calculator (www.projectorcentral.com) to see where you can place your projector and still get the image size you want.
Old 10-20-08, 07:06 PM   #58
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is online now
That size screen and seating distance is about right for a CIH screen...Front row seating is usually about 3 times the screen hieght..and it wouldn't be too wide for that room.
My room is the same length as yours, and I have a screenwall 2' out from the front wall..
Of course, that only leaves enough room for one row of seats..Otherwise, if you want the extra length, placing the fronts at the sides of the screen will be fine..
Prof..
Old 10-20-08, 11:16 PM   #59
Alias: Oil Country
User: #13730
Since: Nov 2007
  Conrad is offline
[You will also want to consult the projector's projection calculator (www.projectorcentral.com) to see where you can place your projector and still get the image size you want.[/QUOTE]
Just curious would you not want the projector always as back possible in a room size my lenght to achieve the largest possible screen. Would not most projectors be able to handle this for lighting up screen?
Cheers
Conrad
Old 10-20-08, 11:21 PM   #60
Alias: Oil Country
User: #13730
Since: Nov 2007
  Conrad is offline
Just curious Prof with a screen this wide and sound field this far apart would the sound still seem to come from the movie or would it be to far apart? Or the turning the speakers to the curved seating position do this for you?
And prof with a room the same lenght as mine did you find 2 feet of screen wall still allows enough room for speakers to perform and play like they are suppose to? And do you have a couple photos of your theatre and your screen wall?
Cheers
Conrad
Old 10-21-08, 12:32 PM   #61
Alias: Zip
Loc: Canada
User: #10408
Since: Jul 2007
The farther back the projector is, the intensity of light hitting the screen becomes weaker.
For example, if you use the projection calculator at projector central
Throw Distance: 9'
Image Height: 45"
Zoom: 2.02x (Full)
Screen Gain: 1.0
Image Brightness = 32 fL
Throw Distance: 14'
Image Height: 45"
Zoom: 1.28x
Screen Gain: 1.0
Image Brightness = 21 fL
When using your projector in high contrast mode, or when there is some ambient light in the room this becomes important. You should still be fine with the PTAE3000 since it is a fairly bright projector.
Old 10-21-08, 07:38 PM   #62
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is online now
Conrad..with floorstanders at the sides of the screen, and angled in slightly..and providing that you have a good centre speaker, then you should have a solid sound field across the screen..
My cinemascope screen is almost wall to wall ,as you will see in the photo.
My room is only 10'6" wide and the screen is 8' wide, so it doesn't leave enough at the sides for speakers..consequently my speakers are mounted above and below the screen..6 in all..and I get a smooth sound field across the screen, sitting just 9' away.!!
If you click on the "My Photos" link, you can see the pics of the construction process..
Prof..
Old 11-17-08, 01:03 AM   #63
Alias: Oil Country
User: #13730
Since: Nov 2007
  Conrad is offline
Question Re: Help in Design of Difficult New Home Theatre New Home Construction
Prof thanks for the pictures your room looks great and I am sure sounds awesome too!!! As I am 99.9 % sure on the Panasonic 3000 now for my projector. What I am trying to decide is to go for either the following screens?
Part Number Da Lite #33099V HC-DMAT 45 x 106 inch 2.35 to 1 ratio 1.1 Gain screen
Da Lite #33110V HC-DMAT 45 x 108 inch 2.40 to 1 ratio 1.1 Gain Screen
If I do not go for Da Lite, I may choose Carada instead. Price and picture quality will be the deciding factor here. I have samples of both here now. Just waiting for projector and Room to be finished first.
I attended a Anamorphic Wide screen demo of a Schneider lens and Meridian projector worth $29,000 CAD last week to see what this Anamorphic deal was all about. Which Prof introduced to me a few months back. WOW and WOW again I am sold on this.
But of course I will not spend $29,000 for that set up I will live with the Pany 3000 with the zoom feature memory mode to create this affect.
What my question is do I go with 2.40 to 1 or 2:35 to Ratio? The Meridian Rep said since all projectors have a 16:9 chip in it to go with 2:35 to 1. But when I spoke to Panamorph guys earlier in year they said to go with 2:40 to 1 ?????
There will be a 3 inch black border around either screen I am sure of. I am so torn over what ratio to go here??? Does this extra 2 inches from 45 x 106 2:35 to 1 compared to 45 x 108 2:40 to 1 make any difference to the actual experience??? Will I notice the over scan here? Or under scan?? What is the safe bet here to go with? What will I see with either screen compared to each other?
Any advice here greatly appreciated on what screen ratio to choose here and why?? As for cost the 2:40 is about $250 dollars more since they charge for the larger screen of 49 x 115 and cut it down to 45 X 108.
Cheers
Conrad
Old 11-17-08, 07:09 PM   #64
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is online now
Hi Conrad..and thanks for the compliment..
Carada would be my first choice, but both are good screens..
[I attended a Anamorphic Wide screen demo of a Schneider lens and Meridian projector worth $29,000 CAD last week to see what this Anamorphic deal was all about. Which Prof introduced to me a few months back. WOW and WOW again I am sold on this.
That's some serious gear!!..No wonder you got hooked..
You need the 2.40:1 ratio screen for anamorphic projection..
The reason you need the 2.40:1 screen is that the 16:9 image is stretched out to 2.37:1 when using a lens..Ideally it should be a 2.37:1, but most manufacturers use the 2.40:1 AR for their screens..
If you are only zooming the image, then you only need a 2.35:1 AR screen..but If you are going to be using a lens further down the track, then I would get the 2.40 screen now and just overscan a bit, top and bottom, or mask the sides if you don't want to overscan.. for the time being..
Hope that helps..
Prof..
Old 11-17-08, 10:25 PM   #65
Alias: Oil Country
User: #13730
Since: Nov 2007
  Conrad is offline
[I]"If you are only zooming the image, then you only need a 2.35:1 AR screen..but If you are going to be using a lens further down the track, then I would get the 2.40 screen now and just over scan a bit, top and bottom, or mask the sides if you don't want to over scan.. for the time being..I]
Prof just to clarify as of now I will use the Panasonic 3000 for sure so that is what you refer to as a zooming method correct? And if I was to use a sled and lets say Isco lense that is the lens set up you mention to go for 2.40 to 1?
But can the image still look good with a little extra zoom even if I am using a 2.40 screen with Panny projector. What happens if I use this set up what would I see here I am not following this still? Sorry for confusion!!!
Is there any disadvantages of going with Panny 3000 and 2.40 screen?
How about split difference any going for 2.37 to 1 screen?
And lastly I spoke to Carada rep a while back and they seem to be great screens for sure what I have read. Why would you choose Carada over Da Lite ?? Just curious.
Cheers
Conrad
Old 11-18-08, 06:03 PM   #66
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is online now
Correct..
Correct again
Yes, it will look fine..The only difference with a 2.40 screen..as opposed to a 2.35 screen (using the zoom method) is that you will have small black bars at the sides...
With the lens method, you won't have any black bars..
No..only what I said above..
It's virtually "six of one and half a dozen of the other"..If you can get a 2.37 commercial screen, then that's fine..It's not all that critical..
Only from what I've heard of someone who had both brands and preferred the Carada..Plus screenshots I've seen on the Carada which were very striking..
I personally have always been a DIY screen builder, so you might want to ask around for other opinions..
I hope I've clarified that a bit better for you..
Prof..
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
