Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater Installation | Systems > Home Theater Design and Construction
  Discuss New HT and Room Treatment in the Home Theater Installation | Systems forum; New HT and Room Treatment Bryan, As a person who has built HTs and understands acoustics, is there a difference of building the treatment into ...
Views: 596 - Replies: 3
Old 11-28-07, 06:49 AM   #1
Alias: Bob_99
Bob_99's Avatar
Loc: New Hampshire
User: #460
  Bob_99 is offline
Bryan,
As a person who has built HTs and understands acoustics, is there a difference of building the treatment into the wall and ceiling covered by cloth versus having the treatment on the outside of the wall? Specifically the wall/ceiling corners and the front wall/wall corners versus something like superchunks or regular 4" panels.
Thank you.
Bob
"There is always hope, even if it is just a fool's hope."
Old 11-28-07, 06:54 AM   #2
Shack Moderator
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
Re: New HT and Room Treatment
Bob (edit -- coffee hadn't kicked in yet ),
For absorption, I would imagine not. It is very common to have absorbers put inbetween ceiling joists and covered with a speaker panel (cloth). The only area that it would definitely not help is with diffusion, as the walls would still be "quasi" flat and parallel. You probably would still need some irregular objects on the walls to help break that up (I like bookcases and DVD racks myself). The biggest problem I see is that you won't be able to get any one panel larger than 16" wide, and all the cavities would be the same width -- maybe a resonance (even though you're absorbing a lot in there)?
Hopefully Ethan or bpape will see this and chime in -- they know a lot more than me, that's for sure.
Good luck.
Old 11-28-07, 06:55 AM   #3
Shack Moderator
Alias: Bryan Pape
bpape's Avatar
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
Hi Bob.
Either can happen effectively. The trick is to keep the isolation. If you have the space for instance to build mini 'closets' into the corners of the room and fill them so they look flush, that's great.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 11-28-07, 07:05 AM   #4
Alias: Bob_99
Bob_99's Avatar
Loc: New Hampshire
User: #460
  Bob_99 is offline
Thank you both for the very quick answers. I was redoing our living room and almost decided to tear out the walls and ceilings but I guess that I'll stay with what I have and save the wife a heart attack. I was also wondering why people who build the rooms from scratch don't do more in wall treatment but now I know.
Thanks again and have a good day.
Bob
« Home Theater Shack > Home Theater Installation | Systems > Home Theater Design and Construction »
Bookmark and Share
Dish Network
