Help with some questions - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Discuss Help with some questions in the Home Theater Installation and Systems forum; Help with some questions 1-- I have a set of rack rails (with all the bolt holes in them), would it be ok to ...
Old 11-28-07, 05:01 PM   #1 (Link)
New Member
Alias: JessyMcK
Loc: St. Joseph, MN
User: #13865
Since: Nov 2007
JessyMcK is offline
1-- I have a set of rack rails (with all the bolt holes in them), would it be ok to frame in a a/v closet and use my rails instead of buying a new rack?
2-- I will need to do an IR extender because my rack is behind me. I don't like the look of the bugs you stick on your sensors. The back of receivers and stuff have an IR in, can I buy a repeater kit and plug them into the back of the equipment or do I need to use the sticky things?
3-- A lot of new equipment has internet connectivity, How do I do this? Do I set up a modem and a router, then just plug everything in?
Thank you.
Old 11-29-07, 01:20 PM   #2 (Link)
Alias: Brent
Loc: Wilmington, NC
brent_s's Avatar
User: #7037
brent_s is offline
Re: Help with some questions
Welcome to the Shack!
Can't help you with 1 or 3. 2 probably depends on distance, the power of your IR remote, and how reflective your walls are.
In my dedicated room, the equipment sits in an armoire at the back of the room. I use a Terk remote extender, less than $30. IR target/RF transmitter is at the front of the room and the RF recvr is inside the armoire. Seems to put out enough IR signal to bounce around inside the cabinet and control all of the components reliably. The RF recvr does include one of those sticky bugs, but I just left it laying loose on a shelf instead of sticking it to a device. The Terk even puts out enough signal to operate the gear via bounce back from a wall about 4' away when the armoire doors are open.
-Brent
Old 11-29-07, 01:31 PM   #3 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is online now
JessyMcK wrote: View Post
Yes but you will need to get shelves that mount to the racks to place the equipment on if you gear doesn't have rack ears.
You should be able to buy the kits, sometimes its better to go with the manufacturer of each piece of gear to ensure proper compatability.
Thank you.
Yes, the receiver will have a setup that you will have to walk through to connect properly.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2,
2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
Similar Threads
A few questions Neilrp General Discussion 3 08-07-07 01:25 PM
Questions Before I Try echomalinois REW Forum 20 03-12-07 10:05 PM
Questions Bob_99 Home Audio Acoustics 3 02-16-07 09:10 AM
New sub, some same old questions Mark Holmes REW Forum 6 10-24-06 10:58 AM
BFD Questions! House Curve Questions! RyanJNielson BFD Forum 5 09-05-06 09:34 AM
Mach 5 Audio
