Center Channel - Above or Below?? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Discuss Center Channel - Above or Below?? in the Home Theater Installation and Systems forum; Center Channel - Above or Below?? When building a home theater with a giant screen, what is the preferred placement for the center channel? Above or ...
Old 12-28-07, 06:27 PM   #1 (Link)
Alias: thxgoon
Loc: colorado
thxgoon's Avatar
User: #6924
thxgoon is offline
When building a home theater with a giant screen, what is the preferred placement for the center channel? Above or below the screen?
Any members have real experience with both?
Old 12-28-07, 06:50 PM   #2 (Link)
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
yourgrandma is offline
Re: Center Channel - Above or Below??
I would say below because you want the front speakers as close to being on the same plane as possible. So unless your front speakers' tweeters are way up near the ceiling, below the screen is better.
Old 12-28-07, 07:13 PM   #3 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
I read that above or below is fine
If you're building your HT and can use a transparent screen you can place it behind the screen ... That's better, I read somewhere
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
Similar Threads
center channel Rodny Alvarez DIY Speakers 91 02-11-08 07:30 AM
Center Channel upgrade. F1 fan DIY Speakers 6 11-21-07 04:37 PM
Dipole Center Channel Anthony DIY Speakers 28 11-05-07 07:31 AM
Active center channel F1 fan DIY Speakers 17 03-19-07 08:40 PM
Center Channel Placement help! robnsin1 Home Audio Speakers 5 01-24-07 05:05 PM
Mach 5 Audio
