Subwoofer orientation? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Discuss Subwoofer orientation? in the Home Theater Installation and Systems forum; Subwoofer orientation? I have been working on the design of my new theater, and I was wondering if anyone had any input ...
Old 03-03-08, 06:05 PM   #1 (Link)
Alias: Justin
User: #15025
Since: Jan 2008
justin.kerr is offline
I have been working on the design of my new theater, and I was wondering if anyone had any input as to sub woofer orientation/placement.
The room is appx. 18.5' W x 23' D x 9' H. I will be using 32 sealed 18" woofers.
I have 3 options that I am entertaining.
I am wondering which option should provide the best listening experience?
Option 1. place the 32 drivers against the back wall, spreading them out evenly, firing towards the front of the room.
Option 2. place the 32 drivers in the front of the room, with 16 facing towards the audience, and the other 16 rear firing, into the front wall, a bi-pole type of enclosure.
Option 3. Place 16 drivers in the back of the room, and place 16 drivers in the front, using the bi-pole type of enclosures.
I also have considered placing subs on the sides of the room, but that seems like a very problematic idea.
Old 03-03-08, 06:11 PM   #2 (Link)
Australian Contingent
Alias: John Simpson
Loc: Hobart, Tasmania
John Simpson's Avatar
User: #8852
Since: May 2007
John Simpson is offline
Re: Subwoofer orientation?
Ummm... 32 drivers? From what I can see, your biggest problem is going to be phase cancellation... there's going to be nodes galore in there.
Why 32? I have no doubt you'd be able to get the same SPL using 4 x 18" drivers in an IB setup.
It's not April 1, is it?
View our home theatre project at the Wychwood website. Comments welcome!
Old 03-03-08, 06:18 PM   #3 (Link)
Alias: Justin
User: #15025
Since: Jan 2008
Same spl with 4? Please explain
Yes I know that the phase cancellation could cause huge nodes, and with this amount of drivers, typical treatments will probably have a lesser effect.
Thats why I was hoping on a placement strategy, that would give me the best odds. lol
I thought about going with a huge IB setup, but was concerned with the limited placement, and adjustability.
Old 03-03-08, 06:28 PM   #4 (Link)
Alias: John Simpson
User: #8852
Since: May 2007
If you go to the IB forums and read the results that guys are getting from 4 and even 2 IB 18" subs, matched to the right amp, I can't see why you would want anything more. Even 4 boxed subs with the right amplification would be more than enough for that size room (unless my imperial to metric conversion is shot).
It's not how much sound you can make, it's what you can physically deal with -- and what gives you the best experience. Have you used this many subs in the past? If so, what sort of amplification do they have? If you need 32 to do what you want, there's obviously a weak link there somewhere.
Tell us a bit more about your equipment and what you're trying to achieve...
Old 03-03-08, 06:36 PM   #5 (Link)
Alias: Justin
User: #15025
Since: Jan 2008
here is my current setup. http://www.hometheatershack.com/foru...-my-build.html
I have 4 EP 2500's with 8 18" drivers now.
To make things work the way I want them to, I need about 5 more db from the subs, and would like 2 more db's worth of headroom. In the new theater my L,R,C, and surround speakers will have 5 more db output than my current setup.
So I am looking for a solid 12db gain over what I have now, from 5hz to 80hz.
Old 03-03-08, 08:48 PM   #6 (Link)
Alias: John Simpson
User: #8852
Since: May 2007
I just had a look over your build post -- impressive stuff. I'd thought at first you might be one of those cowboys that buy multiple $20 subs on eBay and then wonders why they all sound terrible.
While I still don't understand why you need so many drivers, I think I'm out of my league with your setup -- chime in you other mods!
Old 03-04-08, 06:47 AM   #7 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
If it was me, I'd just build another pair of what you already have and place 1 in each of the room corners. I'm not a big corner placement guy but when you can hit all 4, it's been proven to avoid some of the modal issues just as you're looking to do. If you consider each tower as a 'speaker', in theory, you should get an additional 6db from each tower so a total overall gain of 12db as you want.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 03-04-08, 08:57 AM   #8 (Link)
Alias: Justin
User: #15025
Since: Jan 2008
Thanks for your input Bryan!
If I did the four corner approach, I would build 4 new towers, each holding (8) 18" drivers, in a bi-pole design.
The four corner way, would make it very easy for the rest of the room layout.
I wanted to E-mail you also about the room dimensions, while I am still in the blueprint stage.
Would it be beneficial to adjust any of the dimensions, I can go up to 16"'s wider, and up to 2' longer and of course make it smaller.
lol
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
Similar Threads
ECM8000 cal file and mic orientation eqme2 SPL Meters | Mic's | Calibration | Sound Cards 7 07-14-08 10:27 AM
ECM8000 orientation dobomode SPL Meters | Mic's | Calibration | Sound Cards 3 05-03-08 06:55 AM
RS SPL orientation - horizontal or vertical mortod SPL Meters | Mic's | Calibration | Sound Cards 1 09-09-07 12:36 PM
first subwoofer foamfan DIY Subwoofers 8 04-03-07 11:27 AM
Room listening orientation/direction Blaser Home Theater Design and Construction 5 02-08-07 05:16 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
