Insulation - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Insulation
Discuss Insulation in the Home Theater Installation and Systems forum; Insulation I am re-doing the home theater room and is it worth it to rip off the sheetrock on the ceiling ...
Old 01-18-08, 12:24 PM   #1 (Link)
New Member
Alias: Craig
User: #15652
Since: Jan 2008
craigscheer is offline
Insulation
I am re-doing the home theater room and is it worth it to rip off the sheetrock on the ceiling and install insulation bats? The room is in the basement (we have those up North). If so, what is best to use? The R value is probably meaningless in this case.
Thanks,
Craig
Old 01-18-08, 12:30 PM   #2 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is online now
Re: Insulation
Correct. The R means nothing. What you want to do is fill the cavity fully to avoid it ringing like a drum.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 01-18-08, 12:36 PM   #3 (Link)
New Member
Alias: Craig
User: #15652
Since: Jan 2008
Re: Insulation
Should I stuff it full with 2 bats of insulation???
Thanks,
Craig
Old 01-18-08, 12:37 PM   #4 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Re: Insulation
And man does it make a difference. I did that with my riser. First time was one sheet of plywood and no stuffing.
Thing acted like a panel resonator and sucked the bass (almost 1.5 octaves) out of the room. When you walked on it, it sounded like a drum.
Add stuffing (R13 insulation, I think) and an extra layer of plywood (overlapping the seams) and the thing is solid and I have my bass back.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
Similar Threads
A different insulation tkaotic Home Theater Design and Construction 2 01-17-08 08:20 PM
HT insulation using Rockwool and plasterboard Blaser Home Theater Design and Construction 8 11-10-07 04:24 PM
Mattress Sponge as sound insulation and absorption? skoch Home Audio Acoustics 14 11-10-07 01:09 PM
How much insulation in a soundproof room? Otto Home Theater Design and Construction 12 10-22-07 07:14 AM
Insulation materials. Blaser DIY Subwoofers 12 06-20-07 04:08 AM
Mach 5 Audio
