Go Back   Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction
Register
Newbie needs help with 10 questions
Discuss Newbie needs help with 10 questions in the Home Theater Installation and Systems forum; Newbie needs help with 10 questions Hoping for some help from an expert or someone who has "been there"! I'm building my own 7.1 theater (6 ...
Old 01-20-08, 10:49 PM   #1 (Link)
Alias: Tim
Loc: I ain't tellin ya!
User: #1602
purcellt is offline
I'm building my own 7.1 theater (6 seats) in an unfinished (basement) area of our home. (First room is now framed as of this weekend)
I've attached a PDF of the design I've created (to scale) in Excel format. There are 2 pages to the PDF. Page one shows the layout and page 2 shows how it will look from side view.
Here are specs: (my questions are at bottom)
Room 19’ 3” deep
Room 15’ wide
Platform (8"?) plan is to place about 125” from wall (this will be a "wall to wall" and to backwall platform)
First row seating has 94” to eyeballs
Second row 168” to eyeballs
Panasonic PT-AE2000U (planned mounting 15’ 7” from screen)
Elite Cinetension2 110” diagonal screen (16:9 ratio)
Denon 4308ci
Polk RTi 10 fronts (have)
Polk CS400 center (have)
Axiom QS8 surrounds (4)
Berkline “Shack Package” (105” 3 seat width)
My questions:
1-Is the spot I've chosen the correct one to start the riser platform? (it's permanent- it's got to be right)
2- If there is some flexibility in platform placement, which side should I "ere" on - short/long placement?
3- Is the height of the platform of 8" correct?
4- What should I cover it with - MDF or Ply?
5- Should I use joist hangers to get the 2x8" off the cement floor (it's wavy. . .)?
6- Is my seating position choice accurate (use a calculator reccomended here on this forum)?
7- Is the placement of the Panasonic projector accurate (used what I thought was calc on the website)
8- If I upgrade the center what would work well with the Polk Rti10s?
9- I'm going to need to run piping that will allow me to pull current and future wiring - where on this forum is the best info found on type of pipe, where to run and how to attach to framing
10- Best recc on remote lighting control system?
ALL other comments, welcome!!
Thanks
Old 01-20-08, 11:19 PM   #2 (Link)
Australian Contingent
Alias: John Simpson
Loc: Hobart, Tasmania
John Simpson's Avatar
User: #8852
Since: May 2007
John Simpson is offline
Re: Newbie needs help with 10 questions
That PDF you posted was very good -- really helps to picture your setup.
My first impression is that the front seats look really close to the screen... could just be the drawing, and I'll have to sit down and work out what 94" is in metric (!).
A lot of your questions are ones I have too, so let's hope some of the building experts pipe up!
View our home theatre project at the Wychwood website. Comments welcome!
Old 01-21-08, 06:05 AM   #3 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is online now
I may be missing something but I'm not seeing the seated head positions. I'm guessing that the front row is about 119" from the front wall. If so, you're in a bad place - within 1" of 1/2 point of the room length. Remember to place seating first, then get a screen size to fit that distance - then verify that the PJ you want will fill that screen with appropriate brightness and quality/pixel density for the viewing distance. Way too many people pic the screen size first and then try to do seating distance based on that - totally backward and ends up with seating in bad places acoustically.
HVAC supplies should be in the front of the room. Where you have them, the front row will get no airflow and the front of the room will become stale.
If any option at all, entry doors in the front of the room should be avoided. This is for the sake of treating the room in addition to not being distracting to everyone in the theater when someone leaves/enters (blocked views, outside light washing out the screen, etc.)
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Similar Threads
Newbie speaker set-up questions turbochad SPL Meters | Mic's | Calibration 6 12-15-07 01:15 PM
Home Theater Questions (by newbie) gojays_1 Home Theater Systems 0 02-24-07 04:12 PM
Newbie with questions ImprezaSQ DIY Subwoofers 1 01-30-07 04:21 PM
BFD Questions! House Curve Questions! RyanJNielson BFD Forum 5 09-05-06 09:34 AM
DIY Newbie Questions azjimmy DIY Speakers 26 08-19-06 11:34 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
