running electrical - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
running electrical
Discuss running electrical in the Home Theater Installation and Systems forum; running electrical I Know its a bad idea to run electrical wire near audio wire but i am curious if I run ...
Old 01-28-08, 02:52 PM   #1 (Link)
New Member
Alias: Kaos
Loc: Upper Marlboro
User: #15568
Since: Jan 2008
tkaotic is offline
running electrical
I Know its a bad idea to run electrical wire near audio wire but i am curious if I run the electrical in pvc and audio in pvc next to each other to you guys thing i will have a problem with bleed over or an audible hum.
Old 01-28-08, 02:56 PM   #2 (Link)
Alias: brucek
User: #6
brucek is online now
Re: running electrical
audio wire
What are you running exactly? Balanced line level, speaker wire, RCA coax unbalanced?
Old 01-28-08, 03:08 PM   #3 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
the electric fields do not care (much) that the PVC is in the way. However, the PVC will force some separation, which is good. Many times when people run these wires together there's only a few mm or inches of seprataion and the wires are parallel for a long run. That's a worst case where a lot of noise i picked up.
Your PVC idea will keep some separation (hopefully more than a few inches -- like 8" to 1' or more). However the signals can still pick up noise if these runs are parallel for too long. A better bet would be to quickly cross the lines at a 90 degree angle and then make sure the runs are well separated.
That all said: if you have speaker wires in the other conduit, the chance of picking up a signal is very low. speaker signals are very high level, as compared with cable, antenna, or audio (RCA). If you are talking about running video that close to power, you may see a visible distortion, ringing, or ghost lines scroll on the screen). Audio would pick up a hum. Of course many types of RG6 are shielded and can reject some of this noise, so if they are only parallel for a short run, you should be fine.
Sorry if I raised more questions for you than answered. The short answer is, keep them as far away as possible.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
Similar Threads
Running more than one sub on an Onkyo 805 tonyvdb Home Audio Subwoofers 7 12-16-07 03:09 PM
running speaker wires bonj87 Home Theater Design and Construction 3 10-23-07 10:04 AM
Electrical Help with new Denon AV-787 AV Receiver needed Fustern Home Theater Components 6 09-27-07 05:46 PM
Running into headroom problems with my BFD Sir Terrence BFD Forum 2 12-14-06 08:59 PM
Up and running.... garymck DIY Subwoofers 4 07-26-06 10:44 AM
Mach 5 Audio
