dedicated HT room - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
dedicated HT room
Discuss dedicated HT room in the Home Theater Installation and Systems forum; dedicated HT room hi all, this is one of my first posts and i have alot of questions, i'm in the process of ...
Old 02-02-08, 10:49 PM   #1 (Link)
Alias: don5738
User: #15181
Since: Jan 2008
don5738 is offline
dedicated HT room
hi all, this is one of my first posts and i have alot of questions, i'm in the process of building my home theater,its approx. 23ft long and 15ft wide 2 walls are concrete and we are making others, we are staggering studs on 2 walls and floating floor and accoustic ceiling, this is all new to me got ideas from this site questions i have how far to mount projector from wall, i was thinking of painted screen? i read here that it works very well in dark dedicated room also double dry wall construction r13 isulation and r30 in ceilings i could use some insight i could use some ideas for sound quality in side room also what about audio i have all denon components but also bose lifestyle 48? what should i use still thinking
Old 02-02-08, 11:07 PM   #2 (Link)
Australian Contingent
Alias: John Simpson
Loc: Hobart, Tasmania
John Simpson's Avatar
User: #8852
Since: May 2007
John Simpson is offline
Re: dedicated HT room
Hi Don, welcome to the Shack! Feel free to ask as many questions as you like.
Painted screens get mixed reviews -- some people love them (mainly due to the cost savings) whereas others say you would be crazy not to get a proper projector screen. One of the key things to watch is "gain"... if your gain is too high (especially in a dedicated HT room) the image will be extremely bright. A low gain can produce some very deep blacks, but you have to make sure your room and projector are up to the task.
The Denon components sound sweet (I'm a Denon fan too) but the Bose speakers may let you down over time. Simply plan your walls as if you *will* upgrade at some point -- ie: conduit, heavy speaker cabling, sturdy wallplates. Lots of info in these forums about all that stuff.
(Although one of your first purchases could be a keyboard with a working "shift" key... )
View our home theatre project at the Wychwood website. Comments welcome!
Old 02-02-08, 11:40 PM   #3 (Link)
Alias: don5738
User: #15181
Since: Jan 2008
don5738 is offline
John Simpson wrote: View Post
(Although onhe of your first purchases could be a keyboard with a working "shift" key... )
Thanks for the reply and real funny I will try to remember the Shift Key.... How far should I mount the projector from the front of screen? and what about Base traps? I was thinking of seating and home made Risers
Old 02-03-08, 12:19 AM   #4 (Link)
Alias: John Simpson
User: #8852
Since: May 2007
Heheh, yeah, hope that didn't come across as rude. It's all fun until someone runs out of the room crying...
Projector distance depends on the projector you buy -- each will have different throw ratios and sweet spots. Wrap your eyes around this page, as a good start.
There's also a really neat projector online store that does the calculations for you -- anyone remember the URL?
Old 02-03-08, 02:16 AM   #5 (Link)
Alias: Tom
User: #8593
Since: Apr 2007
YW84U is offline
Another Shackster welcome Don!
I think the site John was referring to is this one:
http://www.projectorcentral.com/proj...ulator-pro.cfm
Just enter in the make/model of the projector you're looking for, and you're good to go!
I'm using a DIY screen, and am quite happy with the results. Ultimately, I would love to go with an Acoustically Transparent 2:35 one, but it didn't fit my budget. Always something to upgrade to one day
Cheers,
Old 02-03-08, 06:34 AM   #6 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is online now
I'm confused. On one hand you say you're using an acoustic ceiling. Then you say you're floating a floor and using staggered stud walls. If you want any kind of isolation, you need a drywall ceiling with full insulation above. A drop acoustic ceiling will do nothing in terms of isolation.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 02-03-08, 10:27 AM   #7 (Link)
Alias: don5738
User: #15181
Since: Jan 2008
don5738 is offline
bpape wrote: View Post
I'm confused. On one hand you say you're using an acoustic ceiling. Then you say you're floating a floor and using staggered stud walls. If you want any kind of isolation, you need a drywall ceiling I thoughtwith full insulation above. A drop acoustic ceiling will do nothing in terms of isolation.
Bryan
Well I thought if I added R30 in ceiling and then acoustic drop panels approx. 4inches drop would give air space above for isolation I have seen those type of ceilings in real theaters so now I have a decision to make drywall ceiling or this drop well I will post pics,when i figure out how
thanks again I have alot of questions hope to get answers here.
Old 02-03-08, 01:49 PM   #8 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is online now
That will give you some bass absorbtion for the INSIDE of the room control. It will do zero for bass isolation to the outside world. It will help a little bit with stopping mid and high frequencies moving both ways - but bass is the thing that's the most annoying and hardest to stop. That just takes mass and decoupling.
Bryan
Bryan Pape
GIK Acoustics
Old 02-03-08, 03:00 PM   #9 (Link)
Alias: don5738
User: #15181
Since: Jan 2008
don5738 is offline
Hey Bryan,
Well I know about Bass noise and how hard to isolate, my main concern is my quality of sound inside room secondly noise outside of room I figred if I could stop sound leakage from room the quality inside would be better I might be wrong on this but then again I'm still learning I try and read up on all this stuff
Don5738
Old 02-04-08, 06:05 AM   #10 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is online now
You are correct. Isolating the room from outside sound will reduce the ambient noise level of the room and provide you a quieter, more dynamically capable listening space. Again, unfortunately, a drop ceiling doesn't fit into this plan.
Bryan
Bryan Pape
GIK Acoustics
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
Similar Threads
My dedicated room damonrpayne Home Theater Gallery 6 07-09-08 07:13 PM
Mike C's dedicated HT #1 mike c Home Theater Gallery 62 07-09-08 04:32 PM
Our First Dedicated Theater Room Jeff Aguilar Home Theater Design and Construction 1 10-28-07 12:32 AM
Ideally, which room for dedicated HT? brandonnash Home Theater Design and Construction 5 06-10-07 09:11 PM
Mach 5 Audio
